Another efficiency idea that seems to work for me is cut shorter wood. If you look at most stoves the fire in the back burns more as it goes past the secondaries. The outlet is usually at the front. So the wood in the front has flames and smoke that goes directly up and out without passing the secondary burn tubes or radiating heat to the stove sides. There is no way I can measure it but it seems that having splits 1/2 to 3/4 of the normal length gives almost as much heat as longer splits. This is based on north / south loading and relative to the stove dimensions. Cutting wood about 1/2 the stove length doesn't work as well, because sometimes it won't stay stack and falls forward.
