Begreen, I have been preaching the BBQ for 20 years !! What rock is that large locally? Thanks for your finding's all kidding aside.I found out that they are dandy for firing up the BBQ quickly too.
I'd like to see some user reviews of that system some time. Seems kind of gimmicky to me, but I'm open minded.Even using the Lopi GreenStart Wood Ignitor looks like a lot of work compared to using a SC.
Beats the heck out of newspaper.
You shouldn't. If you are having a problem with weak draft at the beginning of a fire, you may want to try a "top-down" approach with the heavier fuels on the bottom, then the cedars, then some kindling on top of that, then close the door after lighting. The super cedar starter will get the kindling going hot enough to get a draft going, like paper would, but better. The fire then spreads downward. That works well for a lot of people.So do I still need to use the newspaper to get the cold air/draft out of the chimney if I use the super cedar?
I got the newspaper smoke back feed to my room 1 in 3 times when I start the fire. :-(
I never keep the door open after lighting. Full open on the throttle should supply plenty of air until you want to turn it down. Yes, it may get a bit smokey inside at first, but that should dissipate. YMMV as always.
I got my order of 100 earlier this week and have used them to "start" three fires so far. Is it possible I got a bad batch? Whether I have the door closed or cracked, I get a small/moderate flame for 3 or so minutes, then my Super Cedars just go out, leaving me with smoldering kindling and a firebox full of smoke. Maybe it's because of all the hype on here but I am honestly extremely disappointed with this product. Fatwood burns significantly hotter and longer for me than even 1/2 of a Super Cedar.
I have tried building top down and traditional "bottom up" fires with the same results, short lived, poor burn that can't even ignite tiny, very dry kindling, birch bark and small lodgepole pine splits.
Sounds like poor draft. Were you able to get your draft problems worked out?I got my order of 100 earlier this week and have used them to "start" three fires so far. Is it possible I got a bad batch? Whether I have the door closed or cracked, I get a small/moderate flame for 3 or so minutes, then my Super Cedars just go out, leaving me with smoldering kindling and a firebox full of smoke. Maybe it's because of all the hype on here but I am honestly extremely disappointed with this product. Fatwood burns significantly hotter and longer for me than even 1/2 of a Super Cedar.
