I'm not the stove guru that some folks here are. Begreen studies, reads and looks when he gets a chance, and he certainly steered me right suggesting the Keystone. Actually, I will probably go to a welded steel box at some point, to avoid the inevitable air leaks at cemented or gasketed seams. I'd also like to have a secondary stove as a backup (no other heat here yet,) instead of two cats.
If you read and research as you say, you'll make a good choice in the end I'm sure. But there sure are a lot of options out there. Take your time and make the best choice you possibly can. But there are always unknowns, and I feel that I got lucky with begreen suggesting the Ks when he did. It has most of the features that are high on my list. I
had seen my SIL's used Fireview and knew what kind of quality to expect.
I just mentioned the Buck as an example of another cat stove that is rated to run at low output. They also make ZC stoves as do other companies, but we have precious little to go on as far as real-world experience with most of what's out there.I think the EPA numbers have to be taken with a grain of salt in some cases. What you did with the Lopi is all you need to do with
any stove if you just want it to carry house temp overnight, then let it go out most days..load a partial if it's not going to be all that cold. I don't think you have to worry too much about roasting yourself.
I'm trying to not be as in-your-face this year regarding the fanboy hype..but I can only take so much before enough is enough.
I think you now have plenty to consider so I will leave it alone and let you get on with gleaning even more info from everyone regarding the momentous choice that's facing you.
