I just put in operation a 1000 gal LP tank for storage, approx dimensions are 3'D x 19'L. I draw water from the bottom drain fitting and return hot water to top of tank. The tank is insulated with 6" fiberglass. With this diameter, I am finding minimal stratification, 10-20 degrees, as the tank heats. So far I have only heated to about 140F. Example: 170F supply to tank, 120 return from tank, tank temperature 130-135. The 170F water seems to quickly disperses in the tank rather than stay towards the top.
What experience have others had on tank diameter or height and degree of stratification?
I have some more trials to run and will report more if further experience shows a material difference.
In my application the minimal stratification is OK for heating purposes, but a greater level of stratification would be better in regard to pulling heat off the boiler without cycling. At lower return temp to boiler there is essentially no cycling, but as return temp rises, cycling begins to occur. A variable speed pump with more volume at higher temp, or just a higher volume pump in general, might work to reduce cycling.
