Welcome to the madness of a hearthstone soapstone stove. These stoves send way to much heat up the flue. Adjusting the air based of stove top temps is futile. You need to go off flue temps and by the look of the fire. The trick is to get the air control turned down in stages to low as quickly as possible and keep the fire burning well.
Harbor freight has had one that will read up to 1000°.
I've been hand picking mostly ash splits as they are the lowest reading moisture. Im leaning towards my wood NOT being the problem as even when I burn biobricks alone the stove won't get above 325 degrees as read on my stovetop thermometer. Ive been to a couple of retailers looking for an infrared thermometer but all I'm seeing is units that max out at around 600f. Id like to be able to also use it in an automotive capacity and was hoping to get one with a higher heat range. Are the stovetop thermometers that are made for soapstone more accurate than a magnetic rutland thermometer?
I promise I get it
My 05 model has never had gaskets and had gotten to the point where it was get it going and shut the primary down all the way and the leaks and the secondaries kept it right where I wanted it...I thought. I have new gaskets for it this year because it was finally running a little hotter than I liked with a full load. For the new 11 model, it has been a learning curve again. Can't just shut it down, have to do it in increments and still never all the way and I can already tell burn times are going to be longer. Keep us posted when you get the IR.
