So now, let’s take a cold chimney and light the hottest fire we can get in the stove. Absolutely brilliant. Sort of like going to the local college town and watching all those
mart young kids walking out in front of cars. Yeah...they’re smart alright.
Don’t take my words out of context, Ben. Let’s keep it real. I’m not talking about a stove that has went out and warm air goes up the chimney when the door is opened. I’m talking about a cold house, stove, and chimney, not luke warm. And don’t tell me taking the time to warm up a stove and “any “ chimney slowly, metal or otherwise, is going to cause a creosote issue one time or ten times. Even when I burned wood, my stove was started and rarely went out for the year. Get it up to temp, then burn hotter than normal cruise for a 1/2 to an hour each day and there won’t be any issues if the system is built right, clay or not. That’s with older stoves. Should be less issues with these new “cleaner burning “ stoves just by design. I don’t see an issue either way. Maybe you do because most people you deal with are not “regular” forum type people.
My point was the manuals mention quick and hot fires to prevent smoke but they don’t go on and tell the entire story, that a really cold piece of cast iron can crack if you expose it to high heat too fast. I see these cracked stovesnalo the time, cast iron and soapstone. Only two ways they can crack, thermal stress fatigue fro cold to hot or over-firing. Otherwise if heated carefully they can take whatever you throw at them. The same reason antique cast iron stove collectors make casting repairs to cracks by cooling them slowly over a 24 hour period. They often slow heat them even before welding. Those repair methods alone tell you how to care for the castings, by slowly heating and slowly cooling. Natural stone or clay needs the same thing. Steel, somewhat of a different animal. I don’t for a second think I need to tell you these things. You know them.
At least one manufacturer has went to great trouble to deal with expansion and contraction of their stoves to eliminate metal fatigue between the outer shell and inner firebox and to prevent the noises associated with expansion and contraction. Apparently they thought it important enough an issue to deal with it.
Never said those pencil pushers didn’t minimize creosote...I said they don’t tell the entire story, and they don’t. We’ll agree to disagree. I know we’re not talking specifically about cast iron or natural materials, but a cast iron stove, like a good cast iron skillet, both should last more than a single persons lifetime with some common sense approach to proper care and proper heating and cooling...and it’s really that simple.
