I keep reading on here that the more storage you have the better. I just picked up two used 500 gallon LP tanks, one for me and one for my brother. I have access to more tanks with options to get 500, 330 or 250 gallon sizes. Here is what I'm trying to decide.
My boiler is in my basement and I have room for a 500 gallon tank in my basement and/or garage along an adjoinin wall that is 6' higher then my basement. I'm wondering if I should start with one 500 gallon tank and see how it goes or start right off with more storage. I could put one in the basement and one in the garage or stack two in the garage. I could stack two in the basement but I'm not sure how I would get one on top of the other down there and I'm a little concerned about weight.
There is a drain in the basement but if anything happen so that a leak developed the garage would be better. The garage is insulated but not heated where the basement is heated. I also have a 117 gallon tank that I was going to use as an expansion tank but that could also be thrown into the mix to give me 617 gallons.
Such a quandary, what to do, what to do.
1000, 830, 750, or 500 gallons? Stacked or seperate, basement, garage or one in each? What I'm not sure of is the actual advantage of the various volumes as it relates to length of time between fireings.
Any thoughts on the matter?
