Looking for feedback to see if my logic is correct. Gasser heats my shop. 1000 gal pressurized storage, LP tank, horizontal. During winter we may be gone for 1-3 weeks with no heat in the shop during this time. With -30F winter temps, freezing could occur. To prevent this I have installed an electric 12000 watt tankless water heater to provide freeze protection which will be activated by a tank sensor during winter absences (also will activate the circulator). Water circulation is cold return water from bottom of tank, through boiler, to tankless hot water heater, with hot water from the tankless heater into the top of tank.
Here the logic feedback inquiry. Water is most dense at 39F; as the tank cools, 39F water will fall to the bottom until the entire tank is 39F. Then colder less dense water rises to the top until freezing starts to occur, from top of tank down to bottom.
If I mount the sensor in the top of the tank to trigger the water heater "on" at about 40F, the top of tank will receive hot water. This will mix with the cold top of tank water until the differential shuts the hot water heater off, assumed about 45F. Below the 45F water will be essentially only water at 39F (colder water always rising to the top). So, if I keep the top of tank at a constant 40-45F, the entire tank should not be subject to freezing. Is this correct? And with water circulating through the system periodically as the tankless heater cycles on and off, the entire system should not freeze? I suspect circulated water will be at 39F (from bottom of tank), with any colder system/boiler water being mixed with 39F water and cycled through the tankless heater into the top of tank.
Is there a better place to mount the sensor than at the top of the tank?
My system is very simple, just the boiler, with plumbing lines to and from the tank, about 25' away. No other zones. Plumbing rises from top of boiler, along the ceiling, down to tank, and vice versa; no plumbing lower than the boiler, which is about 1' above floor level. In normal operation tank operates as a radiator to heat the shop.
