Hello all,
When I fired up my prototype gasifier last time, I had some issues with what I think was steam formation. I was running the unit, and it was just starting to fire up. Pre-Heat exchanger temps were about 850F. The water was at 50F when I started (the whole system was cold) and it didn't warm up very fast. My temperature controllers hold the stove circulator off until the water in the stove reaches 180F. At 150F, I stepped outside and could here the stove "kettling" or gurgling. Pre-Heat exchanger temps were now around 925F. I decided I might want to start manually cycling the circulator to gradually introduce the cool water to not shock the boiler. I switched on the circ pump and a tremendous bang insued. I immediately shut the pump off. I tried again and it banged again. Water temp was starting to cllimb toward 180F by this point. I finally just switched on the pump. The pipes banged 3 or 4 times before things settled out.
All the piping to & from the boiler is black iron, the primary loop is black iron, and all the piping to/from my storage tank is black iron. The pumps are all on the primary loop pumping toward the various devices. I was running open topped expansion tanks at the time that were elevated about 4 ft above the boiler, with about 2 ft of water in them. I'm planning on going to a low-pressure pressurized system. (about 5-6 psi working pressure)
What do you all think was happening? I'm pretty sure I was boiling the water right around the firetubes while the rest of the water was still well below the boiling point. If it means anything, I'm using a 0010 on this boiler.
