Wow. This is really impressive, from the planning to the execution. Even my pipe dreams fall far short of the work that you are doing. There are all kinds of artistry in the world, this more than qualifies. And, not to mention, you have a 4 year old and a pregnant wife (and a day job!). Well done and keep the posts coming.That was my thought exactly. My boiler would simply boil over out the vent until the low water cutoff shut everything down. But I didn't want that to even possibly happen.
I think I recognize that temp controller, have the same one on my Tundra furnace...I think you are gonna be very impressed with this setup you have now...if not, I am!This morning I came out to leak check. And button up a few other things. I had some leaking unions, junk China copper ones, that I think I got sealed up now. Note to self, only buy gasketed unions from now on. I also had a leaking pex crimp joint, which is a first me me. I checked it with the go/no go and it was good but I suppose things happen. I got it sealed up.
While doing my leak checks the weather started to turn on me. So I made a garbage bag tent to keep working.
I also finished up a few wire terminations and I think I got my flue temp controller programmed.
The controller on bottom left is my flue temp and the A419 is in line with my contactor to control my fan if the boiler is to hot, just as another safety. The blue box at the bottom is a timer relay in line with the flue temp, it turns on my contactor until the flue temp reaches setpoint temp then the timer shuts off and the flue temp controller holds the contactor closed until the end of the burn cycle when the flue temp comes back down then everything shuts off until I hit the "go" button again.
I also have a float switch in the water jacket that tells if water level is good or not. So in the unlikely event of a boiler over it will shut down the entire system before my pump starts sucking air. It runs through this manual/auto switch so if it malfunctions I can bypass it and still operate.
I pulled all the wires and made all the terminations but I can't take all the credit for the wiring. I had someone help by doing my diagram and if that someone happens to read this thread someday, huge HUGE thank you to them!
I'm going to be getting my tanks filled today, hopefully. I'm getting my buddy's well water that runs through his Softener then pumping it into my tanks. I have to make 3 trips to his house to get enough water to fill them up.
What's the thing on top of the air scoop? Is it required for an air scoop to work properly?I haven't fired it yet. I'm going to do a couple small fires to cure out my fresh refractory over the next few days then this weekend I'm going to pour the coals to it, that way I can really watch what's going on.
I'll try to run the circ on high once hot. I'll report back with my findings.
What should my starting pressure be? Right now I'm at zero but I can put some pressure in it before starting.
I also noticed this auto bleeder was allowing air to be pulled back into the system.
I closed the valve and the circ went quiet all most instantly.
=====================================================================================================================================================================================================================================================================================================================My only 2 gauges in the tanks are at the very bottom of the bottom tank and about half way up the top tank. The tank pile is almost 8 feet tall. The circ for my plate heat hx is mounted down low and my circ for the garage hx is about 12" higher then the middle of the top tank.
Yes only worried about pressure on the tank side because my boiler is open system.
=======================================================================================================Yes I'm running webstone propals at each end of each loop.
The auto vent was letting air draw back into my line which is why I shut the valve above it.
What are you talking about excess water escaping through a vent in my roof? I'm confused by that question.
EDIT: I just figured out why my pump is drawing air back in. In my hasty attempt at getting done, I put my air scoop on the suction side of the pump not the pressie side like it should be. I guess I'll be changing that tonight.
I do have some of my expansion in the attic. I have half in the bubble at the top of my storage tank the other half in the rafters of the garage. I plan to allow my bubble in the top of the tank to get taken up then start draining any remaining expansion on the first heating cycle. The tanks in the rafters are there to provide emergency expansion of the tanks take on more heat then intended.
I'm confused all about the vent line. This is a closed system on my tank side. Why would I run a vent on a closed system?
