I have a St Croix and my Versa grate was noisey but it was due to the cam and linkage. I used never seiz on the cam and linkage and all the noise went away.
My motor is silent.
My motor is silent.
THE ROOSTER said:I really couldn't hear much in the videos![]()
macman said:THE ROOSTER said:I really couldn't hear much in the videos![]()
Me either....doesn't sound loud to me.
mnkywrnch said:I've taken the versa grate on my stove completely apart lubed the cams rods everything,the noise is definitely the motor,but it really isn't a big deal to me as the stove is in the dining room.I used the cooper high temp anti seize.
Scoop7707 said:Thanks everyone for the suggestions and research. The noise on the video is barely descernable compared to mine. The noise is definitely in the gearbox connected to the motor. When disconnected from everything else, the motor with gearbox is loud. Like I said, I can hear it over 50 ft away plain as day. It is in the room with my TV and it is very hard to hear the TV.
I looked at the puddle of oil and found it is coming from the gearbox.
I spoke to my dealer and also got a response from tech support at Eventemp. Eventemp said they would work with my dealer to solve the problem. They also said that motor is a "Buy Out" part they have no control over. I don't know what that means. Does that mean the VersaGrate system is made by another company and they cannot specify that another motor needs to be used? I asked for the RPM of the motor so I could see if there was another brand I could replace it with. They said it is a 1 RPM. The closest thing I could find looks right, but is a two RPM.
My dealer asked Eventemp if they could take apart the gearbox to see if they could find out what was going on and still send it back under warranty. EvenTemp agreed. My dealer said the inside of the gearbox was filled with a vaseline type of grease with no gasket between the halves of the gearbox. He thinks the high temp is melting the grease and it is running out the bottom of the gearbox. He scraped all the grease out of the gearbox and packet it with high temp lithium grease. I am scheduled to go down there tomorrow to listen to it run outside the stove.
We ran the original outside the stove disconnected from everything. When my dealer had it out of the stove and running, he disconnected the power to the motor while my back was turned and I exclaimed "Wow, that is better" It was a huge relief. The noise is loud. It shocked him that I knew when he disconnected the power. Turns out my dealer has some loss of hearing and the tones he cannot hear is the range the motor makes its noise in. He cannot hear it at all, but knows it is real because I could tell him when he disconnected it. I cannot say how much of a relief it was to have it disconnected.
I will let you know if the other grease helps the noise. If it doesn't I may try the replacement they would send or maybe, I will buy the 2RPM motor and just run the VersaGrate twice as fast. It would cost about $80 plus shipping, but would be worth it. I don't know if I can take this noise much longer. After a few thousand dollars and a month with the stove, I am ready to chuck it out of the house.
Scoop7707 said:Here is the quote from tech support
"This is a buy out part that we have no control over and if the gear box is not packed tight enough with grease then it will become noisy."
I am wondering if I can repack a new one with good grease whether it would stay quiet. In other words, if the motor is run and is not packed with enough grease, does it do damage to the gearbox making it noisy forever no matter how much grease would get packed in later. We will see. I am sure I have nothing to lose. It is not like I can return the stove. Of course, if I could get the motor out of the one in my dealer's show room floor, it would be as quiet as a mouse.
You missed it.... see the first page....jxnsdad said:Can you post the make and model of motor they gave you to replace the motor that was then packed with lithium? Thank you
