I had a problem with the EKO 60 blowing fuses in its controller, when I had it driving a Taco 0011 pump. The pump is rated at 1.75 amps I believe. As several posters have noted, this puts the total capacity of the controller near its current limit. I noticed that is only blew fuses when starting up the fans from cold, but otherwise ran fine, confirming the idea of the controller being too close to its capacity.
So I hooked up a solid state relay, using the AC signal from the EKO to turn the separate power line to the circulator on/off. However, when I tried it, the EKO turned the SSR on all the time, even when the boiler was stone cold. The green circ light on the controller would be off, but it would still power up the SSR and run the circulator.
Why is this? I hooked the EKO controller back to direct control of the circulator, and it blew the 2A fuse again, but after I replaced it, everything worked well (meaning the EKO controlled the circulator). So it seems one or both of the fans are drawing just a little too much current upon cold startup.
The main question though, is why can't I use an AC control SSR to start and stop the circulator from the EKO? Thanks for any advice.
