The room the stove was in ran on stove temp 5 feed rate 4 and high fan for a few hours. Upstairs living room and kitchen ended up being 74 when I went to bed.
Go bigger, I just installed a p 61a in my house but if I could do it over I would have gone with a 68. Price difference is minimal. I am heating 2500 square feet at around 70 degrees, give or take a few degrees in different areas, but when it gets in the teens I have to crank it all the way up. I do have a 500 sq ft room that has ton of glass and skylights, I'm sure once I get proper window treatments that will help, but I do regret not going bigger. I doubt a 61 a can handle 3500 sq feet in a cold environment.
So I guess that experiment was good, so I am asking this q then - if you run the p61 at say 3 or 4 on stove temp to achieve what the p43 did last night at 5 -is that the only difference, or am I going to be burning more pellets too
And lastly, do you think that switching up from p43 to xxv will only be cosmetic. If I am trying to have the option to get things really hot - then 61 is the choice?
The P 61 will offer some head room for reserve when it gets colder. The xxv will heat differently and offer less reserve. The P61 is a moderate plus upgrade in heating power. The Xxv a modest step up. Not sure how the xxv convection heat would compare. Bottom line, the P61 is rated for your sq ft nicely. IMO you want a stove rated a bit over your houses sq ft, not less. Will it use more pellets? Most likely yes. Any time you make more heat you burn more fuel given closely equal efficiency. The P 61 I believe is 78% efficient. Not sure how the xxv is rated.
