Sounds good foot. To me if done well, it doesn't scream klutz, it says life restored and back to duty. I have a cord with a 5-6 year old splice that is doing fine. Just make sure that the outer insulation wrap stays tight and in good order.
BeGreen said:Sounds good foot. To me if done well, it doesn't scream klutz, it says life restored and back to duty. I have a cord with a 5-6 year old splice that is doing fine. Just make sure that the outer insulation wrap stays tight and in good order.
precaud said:The proper way would be:
Get two sizes of polyolefin heat shrink tubing, one big enough to cover the jacket, the other sized for the individual conductors.
Cut the cable so you're making a clean start on all three wires, even if only one is broken.
Strip the jacket back 3", and each wire's insulation 1 inch or so.
Slip one large piece of heat shrink over each side of the wire, each long enough to cover the repair area plus 1" extra on each end.
Slip a piece of small heatshrink over one side of each conductor to be repaired.
Twist a pair of mating wires tightly together and solder them (flux core electrical solder.) For 12 guage you'll need an 800-900 degree iron and some patience... until the solder flows down into the wires, it's not hot enough.
Use a hairdryer and shrink the tubing over the repaired wire. Make sure no metal is left exposed.
Repeat the previous three steps for each wire.
Now slip one of the large heatshrink pieces over the entire repair, and shrink it down. Make sure there's excess on each end over the jacket to act as a strain relief.
Slip the second large one over the first one and shrink it down.
That's a repair that is as good as or better than new. May even meet mil spec...![]()
Agreed, and yes that call could go either way. If the cord will be exposed and subject to lots of use then, in my mind, the integrity of the jacket becomes very important. And I've not had luck with shrink tape used that way.Gooserider said:A good summary of the procedure, though I might argue with your suggestion to cut any undamaged conductors. I feel that there is no repair that is as good as the original undamaged insulation...
I also cut or tie a knot in the fiber "strength member" cord so that there will be no strain on the spliced conductor(s)[/b] no matter how I'm making the repair...
BeGreen said:Yes, I think GE Silicone II is neutral. Personally, I always use raw metal crimps, then solder them for a sure connection. I use marine heat shrink tubing to seal the crimp connection, then tape. There is a marine heat shrink has a glue like liner that seals things up quite nicely.
fbelec said:there is a splice kit for underground splicing of uf cable.{underground romex} it looks like a small football. about 5 inches in length. it's strong and waterproof. it sells for about 15 or 20 bucks at a electrical supply house. it may look strange but so will a wad of electrical tape.
GVA said:most likely that short section of cord is less than 3 feet, and not good for much...
