"hard black tarry buildup"
This is a creosote buildup, if it had lit off likely there wouldn't have been much left of your venting as it burns at a temperature that exceeds several thousand degrees. 73% of all heating related fires and a full 25% of all residence fires are caused by creosote lighting off.
You should always be on the lookout for buildups in your stove as it is an indication of improper combustion.
That is why you'll see questions about the color of deposits on the back of the fire box above the burn pot, gray, white, or even light brown is fine, black however is a different matter.
There are approximately 180 different compounds that make up creosote, it is fairly easy to control any possible buildup issues simply by making certain the fire has the correct amount of air.
This of course brings us full circle to the mantra that gets preached here on the forum, most problems with a pellet stove are caused by a dirty stove and a clean stove is a happy stove. I could add that a clean stove is also a safer stove.
The reason a clean stove is a safer stove is because it means the operator is making certain that it is burning correctly and that prevents all kinds of problems from even starting or potentially getting out of hand.
Enjoy the heat and as Paul said in another thread "Become one with the stove Grasshopper".
