First, thanks for helping again.
I'm trying to visualize the area you are talking about. The area just above the burn pot for me is just the firebox liner panel. I cleaned that, and behind it, and the two air tubs that are INSIDE the burn pot itself (one on each side of the igniter tube).
Short of cleaning the whole thing with a toothbrush, I really felt like I cleaned it all very thoroughly. The entire exhaust tube channel, the fans, the entire inside of the stove (including removing the firebox liner, pot, etc,), the heat exchanger tubes (as best I could, hard to get up between them), the vent pipe, etc.
Ok, smokey, I'm 99% sure I'm following you. And I believe you are referring to the same plate ohbix is referring to, when he talks about cleaning behind the "lower firebox" which has the two rotatable cutouts. If you are referring to something such as that, yes, I always clean there too. When I'm doing a quick clean, I just rotate the cutouts and clean it out. When I'm doing a weekly deeper clean, I remove the actual firebox lower and really clean behind there. I can actually, when it's out, see the sliding damper plate and the exhaust tube right back to the exhaust blower.
Now what's interesting is that last night, the flame looks good again. No issues. I am wondering that maybe it overfed a bit (smaller bunch of pellets) and I just happened to catch it at that point. I'll watch closely tonight again.
I heard too, that Enviro did ship a replacement convection blower and agitator under warranty, so that's good. But they didn't send/cover (at least not yet) the slightly warped exhaust tube baffle. What are your thoughts on that part and it being a bit bent? Does it even matter really, as long as it slides without issue?
Thanks
Right, no easy way to get this thing outside, but easy to at least roll out of the firebox.
When you talk about "the back of the firebox" and thumping, are you talking about something I can't actually see/get to? Meaning, behind the back firebox liner wall, the wall where the hole where the pellets drop through? If so, yes, no easy way to get access behind that back wall, once I remove the liner that protects it (it clips in front of it).
you are seriouslly overthinking the stove just let it do its thing instead of watching it like a tvNow this is weird. I just looked over and saw the side of the stove just to the left of the back plate with glowing embers. Not sure what was going on I shut the stove off. It looks like embers burning on the back. And I noticed the sides are black ash. It's not thick or anything but black.I just lightly rubbed it and you can see the path the scraper left. Came off like nothing. This pic kind of shows it. I'll clean the stove good this morning but given good draft and flame am I having some other issue? Or is it ok to see some glowing stuff settling here and there?
(broken image removed)
New agitator, sorry. Somehow missed that you posted this a few weeks back. Also, the dealer isntalled the new baffle plate too. I wish I was there to see how he did it.Nope, just the area behind the firebox wall, that stove exposes the entire area that is normally not exposed, you should even be able to get to the heat exchanger tubes with a brush. And since you have a cast unit you can't do any thumping anyway.
A new auger or a new agitator?
