Solar and power wall 3 quote.
Total power in the screenshot is 0.05 (0.06) MW (60 kW), not 500-600 kW?
I understand that 100 homes times 5 kW is 0.5 MW, but their data indicate that other homes maybe are giving less power than you are doing?
Got it. Top number is power my battery is being delivered. 5kw
If all 100 units were discharging at 5kw that’s the .5 Mw.
Bottom number must be the net delivery of the fleet to the grid I I was still sending to grid at 3.5 kw and it read zero.
It was a sunny solstice. 24.9 kWh. I’m averaging 20 kWh/day so far for December. I’m using 16 kWh from the grid each day on average. I think I will use up all my bill credits this month.
  • [Hearth.com] Solar and power wall 3 quote.
The advantage of not being in the cloudy NorthEast.
Reactions: EbS-P
Or simply be farther south and having a better panel orientation: yesterday I had a clear sky day. 9.0 kWh for a 7.2 kW system that is E/W facing.
Reactions: EbS-P
December production is in! I averaged 19.7 kWh per day. 611 kWh for the month. Bill cycle runs Nov 24th - Dec 23rd ended with a 22$ credit. Days are getting longer! Best day in January was the 5th with 26.8 kWh. Getting actual use data I think I’m going to be charging at home more to spend down the bill credits.
Reactions: bogieb
Ah, to have any sunny days during winter would be great - even partial sun would be nice. You generated 4.5x more than I made for the month. I made 137kwh for December and so far this month I'm at 69kwh. Snow days didn't help, neither does my flatter roof, but it is mostly the dark days from heavy overcast. I can't even use my portable panels to charge up my power stations - and those I can angle as needed plus some of them are bifacial so would pick up extra from the reflection off the snow - if there was actually sun.
Reactions: EbS-P
217 kWh in December here. 16 more than in 2023.
THe good news is that my total power for the year has been very stable. 2019: 6.3 MWh, 2020: 6.3 MWh, 2021: .6.1 MWh, .. 6.2 MWh, .. 6.2 MWh, and now in 2024 6.3 MWh again.
I though in 2021 that the decline in performance of the panels had become noticeable. But I guess it's the weather...
I was happy to see the initial 6.3 MWh again, suggesting that the weather variability so far is larger than the slow panel performance decline.
These are LG panels
Reactions: woodgeek and EbS-P
These are LG panels
I've only had my panels a couple of years, but the monthly difference between the years can be staggering percentage wise. Decembers, in order, I have had 165, 180 and this year at 137 (difference of 24% this year against last year). Januarys seem to be stable at 116.7 & 116.2 so it will be interesting to see how this month ends.
February I've had 252 and 416 so that is a huge difference.
But as far as totals, in 2023 I had 6.8mwh and in 2024 I had 7.1mwh (those are my only full years of having solar).
Things no solar designer thinks about down here. When the snow slides of your panels will it hit you heatpump? Last minute design change moved the bottom left 3 panels to a horizontal position on the top right to avoid relocated weather head. So the snow will have to slide down 5 feet of roof and a gutter to land on the heat pump. So I think it’s safe.
Welcome to New England lol
Solar panels or not, we try to put all our equipment on a gable end so it doesn't get smashed by falling ice.
First day of 3x rated kw capacity production for the year. 33.3 kWh. Last 30 kWh day was October 22. Solar and battery storage is such a game changer. I had a 43$ bill last cycle. My dad’s will be close to $500. He has a pool pump and they have a converted garage they have to supplement with space heaters. With two wood stoves and solar the app said I used like 1300kwh paid for 650kwh ams produced 600kwh. The numbers don’t as up as the billing cycle is about a week off the calendar month. It was colder than average. Duke said the Average home in my group used 2500kwh. 1650 was my largest bill is the last two years.
Reactions: stoveliker
Nice.
My bill has been creeping up over the last 7 years.
From $13 to $17 a month.
My battery is infinite - but does suffer from going down twice a year for a few hours. (Until a hurricane strikes ...)
Nice.
Ahh the days. Duke is kicking everyone off net metering here in another year or two. They will end up on our monthly net metering with excess production credited at “market rate” $0.03 /kwh. I’m sure that won’t scale with inflation.
They gave everyone here a time of use rate plan.
New solar folks will have two kWh banks, which sucks because the hours you fill the bank won't be the hours you need the bank the most
We were grandfathered in - my bank is not resetting for another 13 years (or 18? Forgot whether it was 20 or 25 years...)
Reactions: EbS-P
I’m charging a lot more at home now. But not banking any bill credits until my October (solar installed in Sept). I should easily bank enough $$ credits to cover January and February. The EV adds 300-400kwh a month. Can’t bank that much getting 3 cents /hwr. And with this bill I f scheme any oversized systems really take a hit to ROI. It’s better to to pay a little a few months a year than spend an extra 15-20k so you don’t have any bill ever.
I’m rounding. First 40 kWh day! Usage is up since I started charging the car at home. 425 kWh in the past 30 days I had an $88 electric bill.
Reactions: bogieb
Yeah buying an EV definitely changes the balance. Last year we almost broke even on solar credits, going forward we have winter bills to pay. Is the $88 for the whole 425 kWh? Up here in MA National grid takes $0.34 per kWh and I get $0.03/kWh back when I charge off peak. I figured it's almost the same cost as driving with gas but a little less.
The bill was for 750kwh. With riders and taxes we pay $0.16 but with my $14 minimum charge and my $7.50 grid connection fee and my $52 battery credit my cost this month was $0.106 per kWh.
I did the math for the X vs sprinter and the break even cost at current fuel prices is $0.40 per kWh. The X is using 450 Wh/mile from the wall. Not very happy about that number. The car reports 354 Wh/mile.
First 50kwh day! With no heat or AC the house runs on the battery until the car starts to charge.
Bright sunny day yesterday but I didn’t make 50kwh. Umm yeah yellow season…… I sprayed them down. We will see if that makes a difference today.
Looks like pollen time, but I see some shading too.
It was early in morning. About 8:30.
At that hour our panels are mostly shaded still until the sun rises higher in the sky, around mid-May.
