North West winds will make my Jotul118 clone backpuff to make it unusable in the Utah house. That chimney is to short and too close to the higher section of the house. Any other wind direction and it works just fine.
View attachment 284802 View attachment 284803
Thanks for your suggestons! The trees belong to my neighbor and are protected, so chopping down will be difficult.@john81 , besides the stack/chimney height I wonder about those trees on the left of the one picture. Having watched your videos, either your draft is not very good, or your wood is on the wet side.
Are those trees to the left of your driveway yours to chop down, or do they belong to a neighbor? What direction do your prevailing winds come from?
If you don't know, for sure, the moisture content of your fuel, it is probably time to drop US$50 (or less, (plus shipping to Holland)) on a moisture meter with 2 pins in it. Just split open a few of your splits, insert the pins parallel to the grain on the freshy split face and see if you have 20% MC or less. Don't waste you time sticking the pins in at the ends. Once you have a room temperature split opened up, stick the pins in parallel to the grain, near the bark and near the middle of the length. Then push the buttom on the meter.
Next up, if your wood is at or under 20% MC, is to poke around to see if you can find an air quality sensor, a particulate sensor, that can measure PM2.5. Local to me (I smoked tobacco cigarettes for about 30 years), I can't 'smell' wood smoke in my house until the PM2.5 level is up in the 'unhealthy' area. If you go to amazon (I have never been to Holland) try searching on "car air quality monitor" which should bring up a sensor at roughly US$60 with a PlanTower 5003 sensor in it. It has a 2.8 inch screen on it.
You should not be smelling 'smoke' in your house, at all. Even as a never never smoker who never tried marijuana or hash hish or marlboro, ever, if your chimney is working good you should not be smelling smoke inside your home.
I suspect you have minimum a draft issue from possibly the trees to your left as pictured, possibly wood at >20% MC and possibly a chimney or stove leak that needs to be corrected.
I know zero, zilch, nada, jack doodle, beans about your particular stove, but the videos show either inadequate draft or wet wood, and the smoke smell is concerning.
![[Hearth.com] smoke getting into my room [Hearth.com] smoke getting into my room](https://www.hearth.com/talk/data/attachments/285/285103-317c83bb3de209ebbccc5a0c1a17f5bd.jpg?hash=VIwwHTuQIg)
I could see that how that type of cap might be causing some issues. We’re you able to determine if the smoke shield was present@stoveliker: I pre-heated the flue using a heat gun for a few minutes. Then I counted the number of times the paper moved away from the flue (air moving from flue into the room) which was zero. I counted before pre-heating as well, also for three minutes, and counted eight times. (!) So to me it seems pre-heating makes a big difference. After about three minutes of pre-heating with a heat gun, the stove pipes were not hot, just a bit warm. Way colder than during normal stove operation.
@EbS-P: it's this one:
![[Hearth.com] smoke getting into my room [Hearth.com] smoke getting into my room](https://www.hearth.com/talk/data/attachments/285/285148-d3a978eb433b5dbcdaa5334e4fdafd95.jpg?hash=CNfccbPAmy)
for sure try it, if you can just mount it temporarily and have 1 fire you will most likely have questions answered quickly.Hi,
I ordered a digital moisture meter so I expect to be able to check wood quality soon.
I found a flue extension, secondhand:
It will fit on my current setup, maybe not for permanent use, but at least it is cheap and good for testing to see if extending the chimney above roof top will make any difference. It is single walled. Would this be ok, or should it alway be double walled because of cooling?
Hi, thanks again for your reply. I will try to get hold of it asap! 20 euros won't hurt too much. At least it will mount for 1 test. I keep you updated!for sure try it, if you can just mount it temporarily and have 1 fire you will most likely have questions answered quickly.
I'll bet you see a noticeable difference.
If opening a door or window (to ventilate) improves the robustness of the fire, then the stove may need an outside air kit to supply it with combustion air. Normally it's not a good idea to open the stove door during the full combustion phase. Some smoke rollout is not that uncommon with the horizontal rear pipe setup. The smoke is taking the path of least resistance.But after the second refill, 2 hours after start, stove top temp. was 150 degrees C (300 F), I could clearly smell smoke in my room, so I had to ventilate. Then flames increased and temperature raised to 230 degrees C (430 F). As a test, I carefully opened the stove door wide open, but after that again there was a strong smoke smell in my room.
