M
MnDave
Guest
Cast Iron ...... 660 Btu-in/hr- sf - ![Fahr ::F ::F](/talk/styles/default/xenforo/smileys/f.png)
Steel ..............228 Btu-in/hr- sf -![Fahr ::F ::F](/talk/styles/default/xenforo/smileys/f.png)
Soapstone ..... 44 Btu-in/hr- sf -![Fahr ::F ::F](/talk/styles/default/xenforo/smileys/f.png)
By assuming the same temperature differential and firebox inside surface area, I can drop the
and sf units.
I then apply a thickness to each of stove sides based on my best guess.
For cast and steel I assume a 5/16 inch thickness. For soapstone I assume a 3/4 inch thickness.
Applying the thickness I come up with a normalized power output comparison value for each material.
Cast Iron .... 2112 Btu/hr - 100% of cast
Steel .......... 730 Btu/hr - 35% of cast
Soapstove.. 60 Btu/hr - 3% of cast, 8% of steel
One thing that surprised me was that cast iron is superior to steel. I was misled by a graph that I saw which shows that for the same heat input, the steel stove surface measured 900
, the cast iron stove surface 700
, and the soapstone stove surface 400
. I now think that they switched the cast iron and steel in the graph.
Bravo cast iron. You are awesome.
One thing that does not surprise me is soapstones lower power output. This is why they call it "gentle". I'm still confused about the soapstone stove mfg's claims of high efficiency. Soapstone may be able to claim high energy conservation efficiency using an EPA test. But I do not see how they can claim the high "power output" levels unless they are using something hotter than plain cordwood like coal.
I really want to understand what is going on with soapstone. I trust the members who are loving their soapstones. I just don't understand the mfg's claims on the BTU's/hr on their big box stoves.
I am waiting for an "aha" moment on the soapstone story.
MnDave
MnDave
