I have condar in the flue, inferno on the top and a harbor freight ir gun hanging next to it. I like the ir gun but have seen the same version reside back to Celsius everytime you use it, not sure what the deal with that was.
there's a guy in Dover that works at j&j log that does it as a side busness and uses their kiln. If you send me a pm I can give you his #. Seeing that locals sell green wood for $250 a cord $300 for kiln dried was a good deal. I bought 2 cords and it was a true 2 cords maybe more. He didn't charge a delivery charge for 2 since that was the max for his dump truck. I think he might charge for 1 cord.Where are you getting kiln dried cords?
Do you feel the HF gun is accurate enough? Does it match (or close) to the inferno you have on top of your stove?I have condar in the flue, inferno on the top and a harbor freight ir gun hanging next to it. I like the ir gun but have seen the same version reside back to Celsius everytime you use it, not sure what the deal with that was.
Yes it is, matches the top inferno therm by 50*. Like i said though the 1st one i got defaults back to Celsius and my friends didnt, returned it and the next one defaulted to Fahrenheit. Its a nice ir gunDo you feel the HF gun is accurate enough? Does it match (or close) to the inferno you have on top of your stove?
Hey guysI have the hf gun and it works great. That's how I found out how off the Rutland thermometer was. I double checked temps with a rtd probe as well as a thermocouple and they are all within 10-15 degrees of each other. They have it on sale all the time, then use the 20% off coupon on top.
I was thinking the same thing with the gasket material. The only problem is she runs 24/7. Will have to wait. I will keep the cement on the back neat and thin hopefully it wont crack too much. They shortened the snout on the tee and when they tightened the clamp it keep warping a bit. Kept loosing and tightening clamp till it appeared ok. I guess nothings perfect.For the bottom cap you can make a round gasket with door rope gasket. Put it in the bottom of the cap and push it tight and then screw it in. It should seal. If the other part of the tee is going directly into the stove a little cement should seal it up. You shouldn't have to remove that often. I need to take the cap off my tee to sweep so I wouldnt want to cement it on.
I got my stove used and it had a heatshield. I tried using a fan rigged up from my last stove and while it did heat the room the stove is in a little faster it still took the same amount of time for the whole house to warm up. I removed the heat shield this year. I'm not sure if you have a heat shield or not but I would sell mine if you want it.
HelloI got my stove used and it had a heatshield. I tried using a fan rigged up from my last stove and while it did heat the room the stove is in a little faster it still took the same amount of time for the whole house to warm up. I removed the heat shield this year. I'm not sure if you have a heat shield or not but I would sell mine if you want it.
Hi David. Yes I still have it. I just looked it up and it looks like a new heat shield plus brackets is $125 plus shipping. How is $50? Just the heat shield alone is $80 new. I'm away on vacation but I'll be back in Danbury later next week. Did you have any better luck heating after sealing the leaks? I can message you next week when I get back if you would like. - JeremyHello
Last heating season you mentioned a heat shield for a shelburne that you might want to part with.
Do you still have it? If so how much would you want for it?
Thanks for your time
David
Little better.Hi David. Yes I still have it. I just looked it up and it looks like a new heat shield plus brackets is $125 plus shipping. How is $50? Just the heat shield alone is $80 new. I'm away on vacation but I'll be back in Danbury later next week. Did you have any better luck heating after sealing the leaks? I can message you next week when I get back if you would like. - Jeremy
Yes the liner should be insulated for saftey but probably isn't the issue. I only have a 12' -13'chimney (with insulated liner)and have no problem running the stove with marginal draft. This stove breathes pretty easy and doesn't need a large draft. On a couple really cold nights I almost had it run away and get too hot. I think the fuel is the biggest issue if you are running the blocks. I had poor heat when using them.Little better.
Talked to the hearthstone rep and he feels that the liner should be insulated. My installer doesn't think that's the issue but I contacted him today and he is going to come by in a week or so yo pull the liner
