Enviro Empress questions.
Yep- direct replacement is a good way of checking it, ha. Sounds like its fixed. Stay warm.
It seems to be working but I think I changed a setting by accident. The thing starts up normal but once the orange light stops blinking it goes straight to the high setting. Before it would stay on the lowest heat setting and I had to change it myself.
MANUAL MODE: All control of circuit board function is adjusted at the circuit board. To START: Press the ON / OFF button. The stove will turn on. The system light will flash. The Auger Light will flash with each pulse of the auger (the Auger Feed Rate is pre-programmed during start-up). The Heat Level Indicator will show the Heat Level that the stove will run at after start-up and can be adjusted but the change will not take effect until the start-up has finished.
See this manual, page 8
Reactions: Ssyko
