Have you taken out the OAK yet?So depressing. The air coming out the blower is only warm at best
Try different pellets?Yes. No change in fire or temp. If I block the OAK opening with my hand the fire noticeably gets smaller though so I think I am okay on air flow
Definitely something wrong.I just sat on my stove for five minutes to warm up. It's not even hot and it's been heat mode 3 on for about 5 hours now.
....I just sat on my stove for five minutes to warm up. It's not even hot and it's been heat mode 3 on for about 5 hours now.
On 5-9 I hit 900° on that stat and it hasn't shut down. Something to think about though.Mine hits the high heat limiter and shut down at around 550,... you could be approaching that.
hmmm,....On 5-9 I hit 900° on that stat and it hasn't shut down. Something to think about though.
Well, IMO, that is way too close, simply because you can't hardly get behind it if you need to do any work on the interior.Well the stove is three inches from the wall. I can try to squeeze in there. Give me a few
try different thermometers and IR heat detector ,.. the dial therms arent always accurate,.. I have three that are all very close...where your therm is,.. I would think at 900 degrees it should be shutting down....if it were really 900 degrees.Dam it! Now you have me worried!
Probably a bad therm. I have an IR at work I will borrow.try different thermometers and IR heat detector ,.. the dial therms arent always accurate,.. I have three that are all very close...where your therm is,.. I would think at 900 degrees it should be shutting down....if it were really 900 degrees.
excellent,... and in my experience, where you have your therm is normally the hottest spot on the stove,... thats where I keep mine.Probably a bad therm. I have an IR at work I will borrow.
Definitely the hottest part on mine. I am anxious now to find out the temp. I am only on a 1 and reading 550° to 600° range always. Can't imagine if I cranked that baby!excellent,... and in my experience, where you have your therm is normally the hottest spot on the stove,... thats where I keep mine.
