Ya I used to have that, but 2 farmers around me sold there land and now I have 40 new homes surrounding me. Also small parcels across street that was my "honeyhole" are now being expanded on and built on. Now I have to travel some to get access. Just got back from unsuccessful hunt in Ohio. Want to go out today with bow before gun season starts Monday, and its raining pretty good, deciding what to now. Hope your house is nice and warm.Reefwonders said:Schoondog, I know about being busy and wanting to hunt. I walk out the back door to hunt and still too busy. I have at my disposal my 5 acres of woods and 30 more of woods connected to mine and 100 of farm fields.
imacman said:schoondog said:Reefwonders said:Schoondog, That's what it was,the damper was closed. Thanks everyone for all the info,so fast.
Sweeeet. Once you get used to it as Scoop said it is infintly adjustable and will burn almost anything including grass pellets. I really like mine and hope you have good luck with yours.
Schoondog
Schoondog to the rescue!! Good catch there bud. ;-)
Reefwonders said:....I pulled off the sides to check the combustion blower and it operating and clean. Once it does its cool down I'll take apart and check the exhaust blower.
imacman said:Reefwonders said:....I pulled off the sides to check the combustion blower and it operating and clean. Once it does its cool down I'll take apart and check the exhaust blower.
That is the only way to really know if the blower is clean....remove the whole motor/blower unit from the stove. Wirebrush (gently) any ash buildup off the fan blades, and also use a flexible putty knife under the blades on the motor body....get as much of it clean as you can. Be careful of any gaskets....might be a good idea to get some spares as some of them rip easily.
Ash buildup on the fan blades can reduce the air CFM the fan pulls through the firepot.
Reefwonders said:The agitator is turning and the stove does come on without any problems. I did try something before I got into the shower. I opened the stove and flicked out some of the pellets and turned up the heat on the unit to 4 and opened the damper another1/4". The flame is doing great and its burning the soot off the glass.
So when you turn up the heat the combustion air increases. Hopefully that's the issue? I just had it down too low(at 2). I'll see what its like when I get back home later. I think I'm starting to learn at a better rate now. Chalk it up to being a newbie.
I to have a 6039, 2007 model this model only has 3 buttons, A, B & C. I to get two or three values of numbers per each letter (button) pushed. I just installed my stove this year, bought it back in 09 as a slightly used stove and has been in storage ever since. I am still in the learning curve on this stove and have been mapping ALL my set point changes and times let run at these changes. What I revert back to time after time is "A" = 5, "B" = 5, "C" = 9, Damper open 1/2 to 5/8". I get a nice HOT fire with clear clean glass. At this setting it kept me at 70 degrees last night with outside temps reported to be 26 below zero. If I turn it up to "A" =9 & "B" =9 it will heat me out! I have found some of these set points to be for auger speed, firebox air fan, room air fan and I thought I had one more. I'm at work and my notes are at home. One thing I can state is with any changes made, make them small and give them time. I always let the stove go for a min. of an hour before I adjust any other setting/s. I note my results before changing any other settings. Another great tool is a temp. gauge, I have one mounted in my room air vent, huge help in moderating your set point changes. Helpful hints are always welcome! HEAT ON!So I just bought an American Harvest model 6039. I have a question about adjusting the Air/Fuel mixture. In the owners manual, it says "If activation of A and B is necessary".....when is it not necessary? I activated it and tried to make the adjustments to the auger speed and Combustion air blower, but when I hit "A", it brings me to a set of numbers, but only allows me to adjust the number shown under the blower adjustment. According to the manual, the number should be shown under heat range with the blower window blank.When I hit "A" again, it brings me to another completely different set of numbers. What are these. When I hit it a third time it brings me back to my standard Heat and Blower settings. I ran into the same thing with the "B" button. m I missing something? Any ideas? Do I really need to have the A and B activated??......Also, I started it yesterday and approximately 3-4 minutes after starting it, it shut down and showed an E under heat range. I assume this is some type of error, but I have no clue why it did it. I simply turned it back on and it ran fine for several hours.
Last weekend I did some tests on my 3-button 6039 that might help others. I took temp. readings at each of the following settings all of which having my room fan on high. A1, B1 = 121F, A2, B2 = 154F, A3, B3 = 177F, A4, B4 = 202F, A5, B5 = 232F, A6, B6 = 259F, A7, B7 = 287F A8, B8 = 313F. Never got to the 9 9 setting. All these tests were done with the damper open 5/8", never touched it once sett. The temp probe was inserted in the room air vent, last vent hole to the right and probe was 8" long.I to have a 6039, 2007 model this model only has 3 buttons, A, B & C. I to get two or three values of numbers per each letter (button) pushed. I just installed my stove this year, bought it back in 09 as a slightly used stove and has been in storage ever since. I am still in the learning curve on this stove and have been mapping ALL my set point changes and times let run at these changes. What I revert back to time after time is "A" = 5, "B" = 5, "C" = 9, Damper open 1/2 to 5/8". I get a nice HOT fire with clear clean glass. At this setting it kept me at 70 degrees last night with outside temps reported to be 26 below zero. If I turn it up to "A" =9 & "B" =9 it will heat me out! I have found some of these set points to be for auger speed, firebox air fan, room air fan and I thought I had one more. I'm at work and my notes are at home. One thing I can state is with any changes made, make them small and give them time. I always let the stove go for a min. of an hour before I adjust any other setting/s. I note my results before changing any other settings. Another great tool is a temp. gauge, I have one mounted in my room air vent, huge help in moderating your set point changes. Helpful hints are always welcome! HEAT ON!
Mine does NOT have the manual damper, it keeps sounding like it is going to shut off (the room fan) it has been running for an hour now and the fan keeps almost shutting off. Last night it ran for maybe an hour and shut down with the LED blinking above "B". It looks as though this is a HI TEMP alarm, the unit is warm but nothing like my other stove (Countryside Magnum).Hey folks I'M HERE. Sorry I haven't been here much , working and It's hunting seasonReefwonders your problem has to be that the draft damper is closed to much. As scoop said his is out about an inch. The draft damper is nothing more than a manual damper right under the burn pot. The lever is directly in the center of stve right under door. Clean out the burn pot, put in a few handfuls of pellets, some starter jell or hit the pellets with propane torch for a minute to get em goin and close door. Hit the on button after a minute and I just leave mine on auto and heat range 2 (HR-2) on LED. Now pull that lever in center of stove out an inch or more. You should see flame dance and see some sparks coming from burn pot. Once pellets are fully lit you can play with that damper all you want, just be sure its out at leat 3/4 to1" If you are not getting the desired effect pulling out the damper lever than perhaps you are having problem with combustion blower or clog in chimney/vent. If you are burning pellets I just leave mine on auto and let her eat. Of course you can put the stove in many configurations and get many different burns. If the stove reads HR for heat ranges and not CR than its set up for pellets or pellets/corn mix and not 100% corn. The only time I've ever seen my stove do what your stove did is when someone accidently hit the damper in all the way and let it run for a few hours before we noticed. Also be sure the 2 plates at the rear at either side of burn pot are there and closed and be sure the 2 clean outs are closed on bottom of chamber. If the combustion fan doesn't work you should be getting an error code 7 I believe. Also we can try performing the factory tests if you believe the draft (combustion) fan is not working. Lets see what happens.
Schoondog
Excuse me for butting in. New on the forum and new to the 6039. Mine is a used 6039T. I have no manual draft under the burn pot, only a 4" X 6" opening down into the ash pan. I am having a drafting problem according to the light on the new style board. What does this 'manual draft' look like? thanks much. ChieffanThis stove allows unlimited variations on your burning conditions. I'm in my third season with the 6039 and I love it. There is a manual draft under the burn pot and the setting on the board is your draft fan.
My stove don't have a slide. Is this under the burn pot,. or under the stove over the ash pan? My part diagram don't show anything like this either.The center ash pan slid is what is used for draft control. I keep mine out 3/4" if not a bit more when below -15 or so. I took my slide out and used a chisel with a light tap on the edge every 1/4" then used a white paint stick at each tiny dent and wiped off any extra paint not needed. This helps to see my settings better in low light.
I have the 6039 model and it is the slide door right under the burn pot with a little spring handle on it. Also have 2 other slide doors one on each side of the burn pot, these two have small spring handles.
OK. My stove, they tell me is a 6039T. It has the openings, but nothing over the opening under the burn pot. The two on either side of the burn pot as well as on the floor has a heavy angled removable iron piece that fits tight against the vertical opening and sits over the floor opening. I believe there is a difference in models for some reason. I am going to try closing off some of the large hole under the burn pot and see if I can get the draft error light to stay off. Thanks much for the information.
