OK went and saw the Hearthstone Heritage and Manchester-WOW! Beautiful stoves. Nothing like the old VC my parents had when we grew up.
I really liked both (although they have a different look and feel to them) but we are leaning towards the Manchester. I know they are only on the market about a year but I was hoping someone here had some real life experience burning one. Just looking for any thoughts or problems (or raves!
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
LOL)
Hi izzyq:
I just today joined this forum, in part to learn from others what I can about wood stove heat and how to better use it. I inherited a wood stove, a stove made by Haughs, from my grandparents years ago. It became obvious even to me that it needed to be replaced. I stumbled upon this website a month or so ago, and I decided to join to ask questions. Your post offers one of the more obvious places for me to launch into a few issues because I decided to go with Manchester as a replacement stove for the one I had. I have had fire in the box only twice, but already I have a few things I don't like about it. There are some things I do like about it, but I'll get to that in a moment. To me the cons are as follows: 1)the ash pan design with an open end in the back where ashes are easily spilled out as you pull it out is something I think most users will find less than desirable. If you aren't careful, you are likely to spill the ashes out of the back of the tray. 2)The wood handle. It's not really the wood handle so much as that extra inch or so of cast iron that one is very likely to grab in addition to the wood handle that makes this somewhat less than desirable. In other words, if you aren't careful, you might grab that inch or so of cast iron while intending to grab only the wooden handle. You might get a burnt trying to open the door. 3)the so-called 2.9 cf of firebox. It will take a some tricky maneuvering to get the wood to burn in such a way that it doesn't fall into the window. I didn't get my tape measure out, but I think you can safely ignore the .9 part of the equation. 4)I don't know why, but the "safety label" really just sort of dangles there under the stove. I think a better design could have helped to better tuck it away. The manual states this, "After final positioning of the stove the label may be stored between the cable end and the bottom as shown in figure below." The bottom of what? The picture is no real help. But what would help is for there to have been created some sort of clip/s for the label to slide into. 5)There are all sorts of warnings in the manual about not overfiring the stove. However, there are no real criteria given to determine overfiring, i.e., no concrete temperature beyond which you should go or you will overfire the stove. The only information given about temperatures comes with the "Initial Firing" guide. It states, "Manufacturers have selected Stove Bright (R) brand coatings because the product has been proven durable, colorfast, and beautiful at temperatures to 1200 (degrees) F." It goes on to say, "Slowly bring the stove to a medium burn, about 400 (degrees), for about 45 minutes" and then adds, "Increase the burn temperature to a hot burn, about 600 (degrees), for an additional 45-60 minutes."
Ok now for what I think are the pros. I do think the cast iron construction with the soapstone liners is a winning combination. On our initial start up, it took about 20 minutes to feel any real heat coming from the stove, but from there after, the stove did not disappoint us with how it produced heat. 2)The side door load feature is a real benefit for me, and I like it that the front door has the hinges on the right. We also like the large view offered by the window. 3)I did like waking up in the morning to feel a warm stove, and a warm house too, and yes there were some hot embers that I could have used to rekindle a fire. That was after putting wood in the stove at 11pm and waking up at 630am. 4) I like the addition of the leg levelers. My hearth is not exactly the most level place, and the levelers helps smooth things out.
Well that's my initial take on the Manchester, but the real test is forthcoming. Perhaps what I have stated above is of some benefit to you.
