Need to install a sentiment filter on my well system. The small black grit clogs up the faucet aerators, the screens in my garden hose, and is affecting the washing machine. There's not a lot of sentiment, but over time, it does collect, with negative affect.
I'd prefer to avoid a filter that requires buying and changing disposable filters, instead preferring what's known as a spin down filter. These have a fine screen that collects the sediment, and relies on backwashing the screen out through a built-in valve.
Some of these spin down filters are small and fully manual. Others are fully automated with an internal scraper to knock the sediment off the screen, so you don't need to shut the whole system down, to remove the screen and manually clean it in the sink, with a toothbrush.
When I called the well company that services my well, they recommended a couple of American Plumber models that have disposable filter cartridges. He said that iron in the water has been known to cause problems with the spin down models. I'm willing to take the chance that a spin down model with an internal scraper will minimize the requirement to remove the stainless steel screen to clean it.
Any tips on brand and model would be appreciated! Or, if you have high iron content water, and have any experience with the various filter types, please share!
![[Hearth.com] Sediment filter recommendations? [Hearth.com] Sediment filter recommendations?](https://www.hearth.com/talk/data/attachments/305/305099-d4a0e4fedada09673ab39468144f9fe3.jpg?hash=cFdsWSimNb)
That is a lot of sweating.
