I've been reading many of the posts here, and am very impressed with the quality of the information on the board, but I haven't really seen anyone talking about the problem I've been having.
We currently use one of those standard magnetic surface dial thermometers on our stovepipe. However where it's located it is very hard to read because of the way the room is often lit. I have enough trouble encouraging the GF to keep an eye on the stove, it would be easier if we could see what it is doing without straining.
We would really like to update it with a LARGE digital display thermometer (~1" high digits), preferably with a back-light, that we can read from across the room.
The "ideal" unit might also have a user settable alert (or alerts) for high temperatures. Power can be either AC or Battery (battery backed AC would be the real ideal...) If it had a way to output to my Linux PC via Ethernet, that would also be nice, but is kind of overkill. I could potentially use multiple sensor locations, but again that is not needed for other than curiosity. Cost is mildly an issue, I'm willing to pay a reasonable sum but considering that things like digital cooking thermometers can be had for well under $20 I'm not sure that what I'm after should cost much over $50, certainly not over $100...
(I'm also enough of an electronics person that I could probably do minor mods to fix things like power and backlighting if the other features I wanted were there.
I've been searching the web, and all that I've been able to find is the Condar 9-86 or 9-88, neither of which looked all that close, and from some of the discussions I've seen here, it looks even less appealing. I'd like better than 50* increments, and I'm not interested in something that turns itself off regularly. I'm also not all that attracted to the idea of a hand-held IR thermometer - the GF looses the remotes for her TV on a regular basis...
I've also found a few ultra high precision lab type instruments, but they are expen$ive, and again I'm not sure they have a large enough display.
Can anyone give me a suggestion of where to go for something like this? If I were to look for a thermometer that was intended for a different application, what kind of temp range would I need to worry about (assume a flue probe) and what would I need to do to make the probe fire proof?
Thanks,
Gooserider
Thanks,
Gooserider
