Ken, tomorrow I'll take the bar off and run it to confirm the pump is working. Even if the RPMs are slow it should still be putting out some oil. Thanks.
Original post said you'd poured the last of the fuel from a container. If you got some dirt along with the gas, you may have gotten the water from the bottom of the can too. (Unless you use non alcohol gas). It's happened to me until I could get gas without that crap in it.
Drain the tank, flush the lines and filter and fill it with Tru-Fuel till you get it running.
Just my thoughts.
Good luck!
Correct. What I noticed when the pump was not working is that VERY quickly the bar would heat and seize in the bar thus not turning or very difficult to turn. When I finally took the bat and chain off absolutely zero oil was flowing as the pump was completely shot. I was out cutting without winter weight oil in extremely cold temps. Husqvarna dealer who replaced pump for me (under warranty by the way) said the plastic pumps they use these days are absolutely junk and can be destroyed in the manner very easily. There is a thread I started somewhere on here regarding this very incident last winter. Good luck.Ken, tomorrow I'll take the bar off and run it to confirm the pump is working. Even if the RPMs are slow it should still be putting out some oil. Thanks.
Off hand I don't think the low circuit (closest to engine) is the problem. It was idling. Did you try doing the same w/ the high speed adjustment screw?I turned the low carb adjust to all the way to "ridiculous", 1/4 turn at a time with no effect.
That's good to know.BTW, JT, if you ever need to get the carb off, this is a lifesaver.
I just replaced two fuel line and it's the same scenario.
Hopefully you guys will hear new information. For me, the fact I had no leftover parts or a bed spring sticking out is HUGE!!
It seems to start fine. You can hear it bog when I try to open the throttle, and when I hit the primer button when it was running it died.
I have an old habit back from before the first carb adjustment of opening the throttle with my foot while I pull the cord. Even though it wasn't strictly necessary anymore it does seem to start a little quicker.
I can't tell if it's burning the fuel in the line and dying or if any fuel seems to flood it out. This condition is above my pay grade.
Thanks.
Fuel filter OK and exhaust screen's clear? Starting to run out of things. Hopefully it's not something with the piston.
I'm no expert, but maybe we can get to some point where it's running better. I'll go on the assumption that the parts are all good, and the saw needs a tune.
When you start the saw, is it on full choke? Say it was a cold start. Is it full choke, 2-3 pulls and a burp, half choke, 1-2 pulls and go, then a blip of the throttle to to drop it off fast idle, and idle normal? Do you leave the chain brake on?
From the video it sounds (to me, not an expert!) like it's idling way too fast after you blip the throttle.
Is it possible the idle speed is set too fast?
If you fire it up and blip the throttle, then disengage the chain brake, does your chain do nothing, does it creep, does it run full speed?
Thanks for the help.
It has been-
Primer bulb 3x+
Choke on
Pull 2-3x for a burp
Pull again and it fire
click the trigger to get off half-choke and let it warm up.
The idle is set pretty fast for sure. I'll try backing it down tomorrow but I had to start guessing somewhere and at least it was running.
If it decides to run for the full 30 seconds that seems to be the current limit, I can get the chain to rotate but not much more, so it creeps. Full speed is out of the question.
Hope this helps.
I don't use the chain brake unless I see an OSHA truck in the neighborhood!!
You can see the chain starting to move at idle. The idle speed is too high. Lower the idle speed, then try to adjust the low and then the high. Set both the low and high and set to factory specs. Are you sure the impulse line going from the engine to the carb diaphragm is not cracked? Was that the other line in the picture? Also when you had the muffler off did you check to make sure the screen was not completely plugged up with carbon?
I haven't watched the video (too early in the morning, others sleeping) but I like the impulse / fuel pump idea. Bogging on acceleration sounds like a lack of fuel. It might be that the only fuel it's getting is the gas you pump into the metering chamber with the primer bulb. Have you tried continuously pumping the primer bulb after starting to see if that allows it to run?
It's quite a bit different from the 200 and 300-series Huskies I've worked on, so I'm not sure how the impulse connection is made, or exactly where a leak might be most likely. Looking at the exploded parts diagram, I can't even find a separate impulse hose.
I'm concluding that the impulse line is the little short one going from the bulb to the bottom of the carb. It was clear and when I stretched it there were no cracks. The exhaust screen was not plugged and is completely clear now.
Nope, that's not the impulse hose. The impulse connects from the carb directly to the motor, and uses changes in crankcase pressure to drive the fuel pump that's built into the carburetor. The difficulty is that it may not even be a hose; it may just be a passageway through the parts that connect the motor to the carburetor.
