Well, der Husky saga continues. I'll try to lay it out so it makes sense. I got the carb piece this week. Just one fuel hose showed up.
After much weeping and gnashing of teeth I got the thing that holds the air filter and then the carb unit off. Did not disassemble the old carb yet. If you try this on this saw you are going to want a loooooong allen wrench.
I kept cleaning everything as I went. The new carb went in. I did not try to replace the fuel lines. They look like the grommet is built into the hose and I didn't see any easy way to tug on anything to get it out, let alone back in. Lines weren't cracked and I made sure they were clear. I had to get the thing back together before I forgot how it goes. The primer bulb has successfully moved gasoline throughout this endeavor.
Got the linkages, choke trigger and throttle thing all hooked up. Set the carb adjustments to 2.25 turns each. Made a total-guess of 5 turns for the idle screw.
My gut feeling is a fuel line was clogged, but there was no way I'm going to test one piece at a time.
This is a lot like fixing a computer when you get frustrated and try 20 things, reboot, and it works. Who knows which one?
If this thing starts Monday it'll be a miracle.
My one question is how snug should that boot be, and should it cover more than it does. Sorry I don't know the names of things.
Here are some photos for your amusement.
It's possible I could have REVERSED the two wires for the kill switch. I took a photo, but the lighting made both wires look identical. I didn't catch that until I was going to reference it to reconnect them. I'll let you know if it fires!!
![[Hearth.com] Saw loses power during LONG cuts [Hearth.com] Saw loses power during LONG cuts](https://www.hearth.com/talk/data/attachments/175/175503-425cd479c834df64f7f4de5358c71bf4.jpg?hash=H8grmIWrOX)
