zrtmatos
What he said!It's about time somebody gave the correct answer for this thread.. ;-) .. salt or no salt?!
Lot of misconceptions about power here!
1) The power utility supplies a sinusoidal wave form with minimal distortion, ie "pure", produced by alternators. (first pic)
2) A conventionnal home generator also use an alternator but it may produce a slightly less than perfect sine wave, ie with a slight but mostly irrelevant distortion. (second pic)
3) Several decades ago, the first inverters produced a square wave, because it was the simplest thing to do with the then available tech. They made motors humm like mad and power supplies to overheat, so were eventually phased out. (pic 3)
4) In the last 15 years or so, inverters began to use a slightly less square waveform. Despite the sharp edged looking waveform, this will powers a lot of things without much issue, including "delicate electronics". (pic 4)
5) With advancing in tech, is became feasibly at affordable cost to manufacture a pure sine wave inverter, so they did. Those are still more expensive than modified sine wave however. Hence the two kind are still sold to this day for differents price points.
6) Gennies manufacturers began to use inverters in their products as it allows them to throttle down or even iddle with a slight load, something a traditionnal genny can't do.
What kind of inverter is part of your "inverter genny" is a matter of what the manufacturer decided to use. They are usually eager to promote the fact that they use pure since wave in their promo material. Honda and Yamaha have well know such products. A cheaper inverter-genny that doesn't spell it clearly might be suspect in this regard. Maybe the cheap Chineese no-name units.
So, everything pure sine wave and conventionnal gennies should powers a pellet stove OK as is, with no need for power conditionners, surge protectors or additionnal inverters inbetween. In the case of a modified sine-wave, I would say, try it, it might just work!
Ok...so if you are running a moderate size generator (like 5,6, or 7k), why use pellets? I run a 7k during outages. And if I'm making that kind of power, I take advantage of it and run electric space heaters. 3 heaters can keep the house comfortable during the day. I shut everything down at 11 pm and start up again at 6am to get hot water for showers. If I'm paying for generator gas, you might as well get your money's worth out of it.
If you have a generator without an on board inverter, can you run a pure sine wave inverter off a deep cycle battery for the delicate electronics with a battery charger powered by the generator to keep the battery fully charged?
To me, It's like free heat.
I thought the UPS was a short term device - maybe a hour or two - and I am looking for a safe way to run electronics for the duration of the outage. Am I mis-understanding what a UPS is?
I'd sure like you (or anyone else foir that matter)explain to me how to maintain cattle water tanks from freezing in sub zero weather or how to power a machine and fabrication shoip or how to provide light vith a pellet stove.... obviously, you can't. I heat my home with pellets and/or corn and have for years but that has little to do with the rest of the operation, in fact, 17KW in a power outage, in the winter is marginal at best, especially when the shop is powered up. Been considering a 25KW Diesel powered standby with 3 phase 440 output..
We don't live in a house on a lot, this is a working cattle farm and enterprise with all the things (electrical powered that go with it). My typical utility bill is around 350-400 bucks monthly in the winter, depending on how cold it gets and electrical load....
If you have a viable alternative, I'd like to know, if not, don't deride me.
Back to regular programming....
I agree - someday we will have a higher generator. Probably a 30k diesel military generator, of course wired to automatically switch on/off in event of power loss. We have a large setup too and yes generator is the way to go. When everyone else is in the dark... it'll make you smile to go on with life like it never happened.
But if you produce the extra electricity...it is use it or loose it! Take full advantage of that generator and spread the heat to other areas of the house with space heaters. To me, It's like free heat.
You don't appreciate electricity until you have none. You don't buy a generator with the intention of running it at half load. True, here in southwestern CT, we don't get the extreme cold as our friends to the north. So spending $30 or $40 per day for gas during an outage is a lot cheaper then my friends who flee to a hotel. And to run a generator at a reduce load....what are you going to save? Two maybe three gallons a day? Who wants to spend their power outages living in one room around one heat source? If you take your time and execute your plan, an outage should be nothing more then the inconvenient sound of a running generator.
Good question. Some people say about that some new electronically controlled stoves recognize dirty power and shut down. I can't confirm this with my own rig because I have my Gen wired to run the oil heat . It's not worth the bother for me to find out either.Ya know, even though I understand the discussion it's making my head explode! About 25 years ago after the first extended power outage up here that left us with no utilities save for the phone, we picked up a propane-fired 4 cylinder Renault powered, 17.5 Kw Onan with 36 hours on it that was sitting in a farmer's field. We had it refurbished and added an auto-start transfer switch. Since that time it's run as much as eight days at a time powering the entire house including, for the last seven years, our Harman Accentra Insert with nary a hiccup. Although I appreciate the technical dissertations above I thus have no clue what all the fuss us about. Am I just lucky or has stove technology changed so much that a certain AC waveform is now necessary? I somehow can't see my rescued Onan as having an inverter conforming to any of the foregoing specifications.
