If you do end up burning less than perfect wood, don't be too discouraged with the results. Just know that next year will be better.If you cut some dead standing trees with the bark falling off, the upper portions may be pretty dry (more so with non-Oak.) You will still have great drying weather for a while to finish off any wood you get split that is close to being dry. Single rows with lots of air dry the fastest. Small deads will be pretty dry. Stuff already on the ground may be dry.
Could you trade a neighbor who has a lot of wood that's been stacked for a while? How about raiding Dad's woodpile?![]()
If I was going to scavenge dry wood, I can't think of a better place than Texas to do it. Any solid branches that have been lying around in the wind and sun for a while have got to be bone-dry, and probably no rot to be found.If you do end up burning less than perfect wood, don't be too discouraged with the results. Just know that next year will be better.![]()
Be aware that insurance companies can be very insistent about professional installations if that is a concern.Country Hearth 2000 is on my list, and Tractor Supply is the closest chain store. Will check 17VL also.
Thanks for wood tips.
Now, because this is turning into an everything-Aggie-and-wood thread, may I ask about installation here? We went to the local stove store, and they cater to folks who don't worry about money. We have had a local handyman recommended who has installed other wood stoves. My better half has installed several stoves, but in barns and cabins, and he can pretty much make anything work. Do we need a certified installer to do this, or can the two of them handle it? It needs a chimney (none there now) through a metal roof.
They also sell the 2500 and 3000 for those thinking the 2000 is too small. I really like the look of the series mostly the front door which is arched and very wide. The whole stove is nicely proportioned (the 2000) As opposed to my englander which is just square and plain. Gives a nice fire show but a bit low to the floor . I got mine elevated 8 " off the floor but will be going 16 before this winter heating season starts. Same with my englander.Country Hearth 2000 is on my list, and Tractor Supply is the closest chain store. Will check 17VL also.
f.
A cat stove may be out of range for the budget.The size of stove your looking at will be hard to get an all night burn. When going small if you have the extra money a stove with a cat will burn longer and at lower settings so it wont over heat you in the room your in.
