How do you remove & replace the sprocket on the auger? I'm having trouble removing the screw that holds it on the shaft because of the tight working area. This is the Harmon Accentra. I had problems with worn sprockets & the chain falling off so I purchased a kit to fix/replace the worn sprockets. You cannot purchase just the sprockets & the white tension wheel.
Do I need to disassemble more of the stove to get to the sprocket on the auger?
