Any ideas on what to use to replace B+S engine on Huskee 22T splitter. Valve seat, not valve, is leaking . Shop has tried to repair but no luck. I have heard this has happened before on these Briggs engines
Yup...and I'm not a big HF fan, but these lil engines can't be beat for the money (especially with a discount coupon!)I don't know if it'll be a direct bolt on fit, but if you can get a Harbor Freight Predator engine, they are known solid performers. They're actually one brand I would prefer in engines as they're one of the things Harbor Freight is known for doing very well. Prices are fair too.
6.5 HP (212cc) OHV Horizontal Shaft Gas Engine, EPA/CARB
Amazing deals on this 6.5Hp (212Cc) Horiz Shaft Gas Engine at Harbor Freight. Quality tools & low prices.www.harborfreight.com
No comment on HF motors, never even seen one. But 16 gpm on 6.5 hp sounds like a tall order, particularly if you're over-spinning at 120% and over-pressuring to 3500 psi, to keep with Huskee's ratings. I'd recommend something closer to 300cc for that, not the sub-190 cc displacement of most 6.5 hp motors.I have used the HF motors around here on the farm for years for water pumps to bucket lifts. I haven't had on fail yet. I have change over several of those Husky splitters to HF motors. I would go 6.5 horizonal shaft. Good time to upgrade the pump go 13 or 16 GPM two stage and you will need a new love joy and bracket to mount the pump to the motor. Look at Surplus Center in Lincoln Nebraska for the pump and supplies. You won't be able to use a HF Vertical motor because of flywheel issues.
I myself won't set any relief valve on a log splitter at 3500 PSI. I normally set them at 2800 PSI and that will get most folks in trouble. Most wood is split at 1500 PSI or less normally at a 1000 PSI . I have put several 16 GPM two stage pumps on the HF 6.5 and never had any issues.No comment on HF motors, never even seen one. But 16 gpm on 6.5 hp sounds like a tall order, particularly if you're over-spinning at 120% and over-pressuring to 3500 psi, to keep with Huskee's ratings. I'd recommend something closer to 300cc for that, not the sub-190 cc displacement of most 6.5 hp motors.
The HF 6.5 is a 212ccI'd recommend something closer to 300cc for that, not the sub-190 cc displacement of most 6.5 hp motors.
16 GPM at 2800 PSI requires 6 horsepower theoretical, so I'd believe you're getting by fine with 6.5 hp, if your net efficiency (pump + lovejoy + hose losses) is near 92%, or if the motor is actually capable of a few % more than rated power.I myself won't set any relief valve on a log splitter at 3500 PSI. I normally set them at 2800 PSI and that will get most folks in trouble. Most wood is split at 1500 PSI or less normally at a 1000 PSI . I have put several 16 GPM two stage pumps on the HF 6.5 and never had any issues.
I wish you could link those threads you mentioned.. I'm currently getting ready to do a Predator 212cc swap on my 20+yrs old Huskee 22ton and my mind was going through all the possibilities.. there's a sale on right now at HF and the Predator 212 was only $109 (bought one today) I was probably gonna just keep the original 11gpm pump (I believe that's what came stock) with an eventual upgrade to a 13gpm but I'm pretty limited in my confidence in my skills as I've never done this before.You have seen my thread(s) on hotrodding this very model of log splitter? Got mine down to 8 seconds full cycle, with pretty minimal work, and could push it down to 6 seconds with a few tank and cylinder bung changes.
Since the engine was probably 80% of the total project cost, I'd be using this as an excuse to do some upgrading!
The engine I chose (Intek 21R707) was total overkill, aiming to support a future upgrade to a 22 GPM pump. But it's pretty easy to get up to 16-18 GPM with the existing cylinder and tank, and a modest engine upgrade to 7 - 9 hp.
Just a warning, log splitter builds/mods are a slippery slope/rabbit hole!I wish you could link those threads you mentioned.. I'm currently getting ready to do a Predator 212cc swap on my 20+yrs old Huskee 22ton and my mind was going through all the possibilities.. there's a sale on right now at HF and the Predator 212 was only $109 (bought one today) I was probably gonna just keep the original 11gpm pump (I believe that's what came stock) with an eventual upgrade to a 13gpm but I'm pretty limited in my confidence in my skills as I've never done this before.
But they also had a Predator 224cc that was $40more and I got considering "could that engine spin a 16gpm pump?" Also, do you think that the 212cc could do 16gpm? I really don't wanna lose any splitting tonnage as there's been a couple of times I was unsure if the original setup would push through a big branched log but it always did. I don't quite understand the PSI ratings on the compressors and how they are achieved or adjusted.. are they a built-in design feature or are they adjustable because you mention in your last comment about 2800psi at 16gpm requiring 6.5hp theoretically but saying you'd need 3500psi to get the full 22 ton out of the 4" cylinder.. so is that just inherent in the pump or is that a adjustable level of pressure in said pumps? I've seen most pumps only state 3000psi as their pressure yet I've seen some by a company called Vevor that say 4000psi.
I just really wish for a fuller understanding of the subject.
That's great! I already have a passion for modded chainsaws, why not splitters too?Just a warning, log splitter builds/mods are a slippery slope/rabbit hole!
First of all, on the specs, they all lie. Most of those pumps will do 3000 PSI, very few will do 4, especially the cheaper ones!
Also, the tonnage rating on most splitters is complete pile of steaming BS! To get the tonnage they claim all the components would have to do way more than they are even capable of (including the hoses sometimes) in most cases, and its been this way forever.
Here is a good site to use to learn about hydraulics as related to log splitters, and to calculate actual numbers. https://logsplitterplans.com/calculators/hydraulic-cycle-calculator.htm
After heavily modding a Huskee 22ton last year, I can tell you that any splitter that makes an ACTUAL 22 tons, would split boulders...I am running a pressure gauge now and even when splitting nasty ole stringy/crotch/knots that the gauge very seldom goes over 1k (so ~6 tons) the gauge barely even comes off the zero mark to split the average log.
My old Champion splitter had a 13gpm pump with a 196cc engine and it pulled that without any trouble at all...my new splitter is powered by both a 8 hp Predator, then a quick swap makes it electric powered, by a "5hp" motor, which by actual amperage is more like 4 hp. (but electric motor hp is different than gas, due to much higher torque)
I went with a 16gpm pump and the electric motor will pull that pump up to 2500 psi (so ~15.5 tons) (which by coincidence, is same rating as my hoses) the 8 hp (301cc) engine doesn't even know its there, so I have exactly zero doubt that a 212cc Predator would pull the 16gpm pump. You mentioned that your splitter sometimes struggles on some pieces, but never stalls...that is just where it shifted into "low gear", which is exactly what 2 stage pumps like this are made to do...high speed/low power most of the time, low speed/high power as needed.
If you did need to adjust the 16gpm pump relief (max) pressure (for less hp requirement) that is easily/quickly accomplished by taking a plug off of the pump and turning a screw...this adjustment would control how much HP it actually takes to turn the pump at max pressure. (because these are positive displacement pumps)
I bought mine from Rugged Made, but I'm not sure it's really that much different than the Amazon/eBay pumps...if you do order one of those at least get one from a reputable vendor with good feedback on both them, and the pump you buy.And do you have a decent company that you'd recommend for a 16gpm pump? Or are any of the $100-120 pumps available on Amazon or the like gonna cut it?
I moved everything to the other side, down low...With a Huskee splitter and Horizontal shaft engine it's going to be near impossible without completely redesigning the whole layout
When I looked into it awhile back, it seemed pretty much all of these pumps are made by Wuxi Bucher, even the Rugged Made. Maybe buying a name brand gets you better warranty service, but not a different pump.I bought mine from Rugged Made, but I'm not sure it's really that much different than the Amazon/eBay pumps...
