I am in an EPA non-attainment area for air quality. Starting probably Feb 13th, about two weeks from now, I am going to have to deal with opacity.
On a hot stove I am fine. I am limited to 10 minutes per hour at 30%, less than 30% for the other 50 minutes in whatever one hour monitoring period. I can do a hot reload and re-engage the cat in under two minutes. With the cat engaged on 12-16%MC cord wood I am running at or near zero percent opacity.
On a cool reload, with a decent bed of coals in the ash first thing in the morning I can generally get the cat re-engaged in 15-18 minutes.
From my driveway I observe that with the cat engaged my opacity is pretty much zero percent. My wife actually signed me up for the EPA method 9 certification class. I should be an EPA method 9 daytime "VEE" sometime in April. The V is for visual , the first E is for Emissions, and I don't even know what the other E stands for yet. My detached plume is pretty darn clean. Below about -20dF my plume is attached to my stack, but it looks pretty clean on the downwind end.
On cold starts I got the 30% limit for ten minutes of any hour "except during the first twenty minutes after the initial firing of a cold unit when the opacity limit shall be less than 50 percent."
I did a cold start tonight after an unscheduled shutdown. See "my neighbor saw flames out of my chimney" thread. Starting with the house at 62dF ambient from the oil furnace, the lever in bypass, and the top of the chimney at ambient -25dF it took me twenty six minutes to get the cat engaged after I applied a lighter to the tinder under my kindling.
I am not sure if the attached plume I see on cold starts is measurable, or if I need to be evaluating the downwind end of the plume. The attached plume I see on cold starts is way over 50%.
How much kindling do you use on cold starts to keep the wood smoke police from knocking on your door? I used about a 2x4 split into many many pieces tonight, I think I should use at least double that next time.
Thanks
Thanks
![[Hearth.com] Regulated burners - cold start tips? [Hearth.com] Regulated burners - cold start tips?](https://www.hearth.com/talk/data/attachments/152/152232-94faee3901cf548e278736f663921260.jpg?hash=sJB18Gbxc3)
IMO wood at 25% on a meter will burn just fine.![[Hearth.com] Regulated burners - cold start tips? [Hearth.com] Regulated burners - cold start tips?](https://www.hearth.com/talk/data/attachments/152/152244-3a627e03eeb433754656bad0ca9f499a.jpg?hash=rro78e5dss)
