Re-load on hot cat
Cburke
Burning Hunk
179
Honeybrook Pennsylvania
Hello. First winter with my ashford 30 and so far love it still learning. Question about hot reloading. Is it ok to add wood to the stove to extend the burn while I’m at work so I don’t have to come home and re start from cold? When I wake up I’m at around 40 percent wood left and by the time I’m home the fire is complete and no coals left. I worry about damaging opening the door to throw a few splits in while the cats still active with a half load or less in it. Thanks so much
You can certainly do that. However, you should open the bypass for a few minutes before opening the door to let the cat cool down (depending on how hot it is, if barely above active zone, probably not all that long).
That sends the gasses directly into the flue and the exothermal reaction in the cat ceases, allowing it to cool down a bit. Not to room temperature, of course, but lower than the active state.
After the reload, open the thermostat wide with the bypass still open, wait for the wood to catch on fire (couple minutes) and then close the bypass and dial down.
Awesome that’s re-assuring I was afraid of thermal shock to the cat. I’m burning insanely dry American beech this year and it doesn’t burn quite as long as the white and red oak I primarily burn.
Yep, there are people that just keep topping off their BKs all winter long. Never using a second match.
I reload my princess every 24 hours and rather like to let the house cool off a bit before a full reload since starting up that fresh load releases a little burst of extra heat.
Yea it’s quite a different experience than my last stove which was an epa tube stove. That stove had to be run in cycles. I really love that I can have the ashford run 24/7. With little effort. My old stove was 4 loads a day to keep the house comfortable in the dead of winter this has been 1 load a day so far we hit a chilly stretch here so burning a bit warmer than we were last month. I’d imagine come January and February it’ll eat up some wood. But for now this is a nice change! And not a melt your face off heat to which I like.
Reactions: GG Woody and Tron
If you need more heat you can almost crank through 4 loads a day. The ability to slow it down and match your home’s needs is very nice.
Reactions: GG Woody
Running WOT, I would assume four loads a day are easily reached. That's a lot of BTU's.
Since the thermostat shuts the throttle down when the burn rate is too high there is a maximum fuel consumption rate. Really for any stove but especially for the BK. How many loads per day you could get through would depend on your fuel quality, skill in loading, and what defines a "load" but I never have this problem in my install. Some folks have undersized stoves and complain about not enough heat from the BK, those folks might be able to share experience about full load burn times at full throttle.
Reactions: Tron
Even then it's dependent on the draft; the air inlet may be closed but the airflow thru the stove will then be determined by the suction of the chimney.
So there is no universal max burn rate.
Reactions: Highbeam
