Hi guys!
I'm writing from Central New Jersey. I have a pre-fab modular garage / workshop on the property. It's about 38' x 26' x 8'. The WALLS are 8' at the eaves rising to 10 feet at the peak. It's got a large overhead door, but this isn't opened during the winter. It's got one standard-sized door and four windows. A portion of the garage is used for the storage of two riding lawn mowers, two ATV's and a small go-cart.
I've enclosed a small area about 10' x 15' with a heavy gauge plastic drop cloth, and use this area as a wood-working shop. I purchased a Edenpure heater (the large one) with the expectation that it would heat the area, but I was wrong. It doesn't put out enough BTU's to do the job.
Right now, it's about 30 degrees or so during the day, although it sometimes gets colder in the middle of the winter. I don't plan on spending much time out there if there's a lot of snow on the ground, but I'd like to do some light carpentry out there from time to time.
I'm interested in the Mr. Heater MH42T Triple Heater which mounts to the top of a 20 lb propane tank.
This is the item.
My question is - Do you think this will suffice for heating in the cold weather? Do you think it would be safe with the plastic drop sheeting? Another concern is the possible presence of gasoline vapors from the lawn equipment, but I don't that's a real threat.
This is the item.
