John, thank you for posting your pictures. It's surprising such a small sized unit could dheat the amount of basement space you have. But I suppose its about the same size of a water to air heat exchanger I've over my furnace that heats 3000 sq, feet. Coincidentally, I found a calculator on the Modine site that figured out for my application that I'd need the same sized Modine as yours to heat my shop when the outdoor temperature is at zero degrees F. It rarely gets that cold here in the western part of Virginia. I'll have to fine tune the calculations to allow for a worst case scenario of water temps in the 140 degree range, but this looks promising. Supply House (formerly Pex Supply) carries that unit so ordering would be simple too.
Do you have a separate pump supplying it's hot water? I don't imagine a hydronic Modine comes with its own pump. If so, would you mind sharing what size or kind pump you have supplying hot water to your Modine? I promise no more questions. You've already been very helpful John. I think this might be a lot simpler installation than a separate w/a hx and air handler. Thanks again,
Mike
Mike
