question about moving heat from stove room
that was me loading up the box and doing an overnight burn. well not totally full did the old log cabin with the center hollow
that's kind of cold with all that heat put in there. like I stated before, i stop feeding the stove around 9:30-10pm. in the morning, it's never been under 66 d.
do they have state energy audit programs where you live? if so, sign up. if not, get a audit by a good private contractor. always best to hang onto every btu you put in the house for as long as possible..
OK guys. I decided to redo my house plans to make things more crisp and readable. I wanted to show the exact location of the wood stove and the exact location of the fan.
The blue arrow is the fan and the red oval is the stove. mind you the brick hearth has an L shape to it. i had the fan right at it and its about 18-20 feet from the stove area. The stove room is very open concept which helps spread the heat in that room. my problem is that the heat didnt really move too much towards the bed rooms.
am i doing something wrong?
That is where you want to try the fan. Now you just need to get more heat going. I would go to the local hardware or grocery store and get a couple bundles of dry firewood. Give that a try, burning a full load of at least 5 or 6 splits.
When you say that everyone was advising you to get the Clydesdale, are you referring to the dealer and salespeople? Or on another forum?
i have seasoned oak...been split and stacked at least a year. actually the wood im using now is left over from last year....so its been around for at least 2 years.
As many people here can attest: oak needs a minimum of two year to season better three or more. Did you split a few pieces and check them with a moisture meter in the center of the freshly exposed surface? The reading should be below 20%.
im going to post a picture of me filling the box and starting the burn..ill let you guys be the judge.
i do not have a moisture meter
how are you measuring stove temps? are you getting it hot enough? that is my big battle right now. trying to figure out how to properly measure stove temps on an insert. i got a magnetic thermometer and IR thermometer. both help, but still working on how to get accurate temps with them. when i get the stove real hot, i get much better results. pretty sure i got the stove top to 450-500 last night, and got stove room to 75. highest temps i got so far, and outside was 25d.
also, like others said, moisture meter is very helpful.
Good luck.
luckily christmas is around the corner..hahhaha
need bunch of gadgets. sucks being a rookie, but by next year its going to get pretty serious.
Can anyone confirm this working?
If you crack a window at the end of the house you want the heat to go to it will. Warm air takes up more room then cool air, so the warm air will move to the cracked window and push the cooler air out the window. The room won't be as warm as the central part of the house, but will take the chill away.
How many square feet is your home and what size stove are you running?
Has anyone else tried this? Maybe it'd work on a calm day, but goes against my logic. Thx.
When you warm air it takes up more room then cool air. The air is pushed out the window not drawn in. We have a zigzag from our living room through our family room to our laundry room/bath. This is the only method that gets heat into that area. It also keep the family room warmer.
so i listened to some more advice.
i started with the hot fire with small wood and then load up and close up the damper.
the difference from today to yesterday is pretty considerable. Have den area over 70. the two closest temps are at 70 and
here is a pic of what the fire looks like right now with the damper nearly closed
(broken image removed)
i also put a fan in the BR1 and aimed towards the stove room as best i can and will see if that will help.
will keep everyone posted
Reactions: Grisu
No real need to wait until Xmas. Any cheap moisture meter ~$20 over the internet (Amazon, Ebay etc.) will do or try this one:
http://www.harborfreight.com/digital-mini-moisture-meter-67143.html
If you don't have a thermometer yet look also at this one here: http://www.harborfreight.com/non-contact-infrared-thermometer-with-laser-targeting-60725.html
With Black Friday not far away you may get it even cheaper soon.
You can also check your moisture content with a multimeter the sticky is at the top of the wood shed forum. Wish I would have read it before I bought mine at lowes. It works ok. I just look at an think man I could have gotten more saw chain.
i have baseboard heating. but my AC blower unit is in the attic and i have the return right next to the hearth. i will try to put on the fan tonight
I turn on my fan and use the ventilation system to distribute the air and it works well. I measure the temps at the registers before I start the stove and see a 5 degree increase after about an hour or so. My return is in the stair well just above where the stove is in the LR so maybe that is why it works well?? It also helps to cool the LR where it can get really warm. I need to get one of those timers as I don't want to run the fan all the time.
