USMC80
what temp are you running the Clyde at? You should be running full loads with a complete burn cycle.
House is just under 1700 square feet.
The stove is a clydesdale 8491, 74,000BTU and is rated for a 2400 sqft house.
My running times are this:
Get home at 5, start fire and get it going...replenish the beast all evening. at around midnight i fill up the fire box and keep the damper nearly shut. i still have red coals in the AM. Wife said the fan was still blowing around 7am.
i have insulation in the ceiling, in the floor and in the exterior walls. most windows are new, but the older ones get the plastic sheet treatment during winter.
as for the insulation, would that just need to be done in the attic?
I really think the clyde should be able to keep that house toasty, especially with temps only in the 30s at night.
In principle, I agree that it should be able to do more than it seems to be doing. 69 F close to the stove are not that impressive. However, I am wondering how cold the house gets during the day. If it is below 60 and the Clyde is busy getting everything warmed up during the evening I can understand when it struggles to get the bedrooms warm. It also looks like a big, masonry interior fireplace. That will suck a lot of heat until it is warm. I have a similar setup and from a cold start it takes about 3 hours before the house starts to get really warm. It is nice in the morning though when the brick still radiates the heat while the stove is pretty much out.
i guess worst case i can keep the oil heat on during the day then let the stove take over in the evening and overnight. Was hoping to heat as much as possible with the stove and limit oil use.
If you crack a window at the end of the house you want the heat to go to it will. Warm air takes up more room then cool air, so the warm air will move to the cracked window and push the cooler air out the window. The room won't be as warm as the central part of the house, but will take the chill away.
How many square feet is your home and what size stove are you running?
this morning it was about 63.5-64 degreesso at 7am when you wake up, what's the temp in LR, Kitchen and den?
Bingo! Load her up I guarantee she will heat your house up nicely. Should see that den and living room in the 70si dont do a full load, i have a friend with a wood stove who was telling me to do one log at a time.
this is feel is a big part of the problem. i am glad and very appreciative with every ones input. It is good to have input from seasoned veterans.
that was me loading up the box and doing an overnight burn. well not totally full did the old log cabin with the center hollowis that without running the stove past 11pm?
well he did let me borrow his splitter which did all the heavy work for me so i will let him pass.now to find out what you did to piss your friend off
I fear he is burning wet wood. If your wood is not seasoned and you pack the stove full with it you will certainly just get a smoldering mess. One log at a time may be the only way to keep the fire going.
