S
ScotO
Guest
B of H, I used 1" thick insulation and overlapped it by half, only did it around 5' into the space. i wish I could have insulated it the whole way but I couldn't do it, on count of the way I had my OAK mounted. As for a trap, just make a hump "upwards" with your flexible pipe (creating a little "hill" that the air has to get up and over). My OAK works pretty darn good.Similar situation here - I have an unheated crawl - it's well insulated though and it stays @ 50 deg in winter. I won't see the OAK but knowing there's any moisture or condensation happening there would drive me nuts. Thanks for the info and the sanity checks.
I don't recall reading anything about length of OAK from SBI, but their OAK kit (adapter / flange and vent hood) is 5" diameter - they specify 5" flex pipe, which I think is a lot of pipe for fresh air. My run will be approx 15' - a few inches down from under the hearth / pedestal, a 90 deg bend, then straight across horizontal and out the wall. Scott how much insulation did you need to use around the pipe - inch or 2 thick? or more? Also interested in the "trap" you mentioned - maybe something to add here too since I'm in the process now...?
When you form the hump, the bottom arc of the hump MUST BE slightly higher than the top of the straight run on the intake side of the hump. Hope this description is clear enough...this is another example of how one picture would be worth a thousand words.
