First of all thank you in advance, discussion groups are the Internet do-it-your selfers best friend!!
My stove is approx. 3-years old and short of a few missed ignition errors has been fairly good. I burn oak pellets. I recently pulled the insert out, vacuumed out the blower, fire pot, and heater plate. I put in a new blower gasket and inserted the stove back into its place. I turned on the stove and it augered pellets into the pot. The ignition coil heated up and ran fine. I ran it for approx. 20-minutes and shut it off. A few days went by and I turned it on and the pellets dropped in however the coil does not heat up. I pulled off the sides of the unit and unplugged it and plugged it back in and again the same result. I did notice a red blinking light on the unit behind the power supply. I do have the unit plugged into a surge protector.
Any help again is greatly appreciated!!
Thanks
Thanks
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
