If you're not electrically inclined, then you probably don't have crimpers for wire terminators, a voltmeter or the parts either. I am trying to be nice :red: but maybe you shouldn't do it..... If you have a friend who has the tools, get him to make up a Y harness from 20 gauge wire for you with a female spade connector at each end and about 24" long. Out of one end also crimp in a short length of wire about 6" long and put a male spade terminal on it.
Now you've got to reach around behind the stove and (OH, UNPLUG THE STOVE
) find snap disc #3 and pull off both connectors. Bring them around front so you can measure the voltage. Plug the stove back in but don't turn it on that it calls for heat. Connect one end of the voltmeter to the frame of the stove anywhere and with the other voltmeter lead find out which of the snap disc #3 terminals has 110 volts. Label it with a piece of tape. Plug the male spade lug on your new wiring harness you made up into that female end. Then take the female end on your new harness that is near the male end you just used and attach it to snap disc #3. Plug the other connector of the original leads onto the other terminal of the snap disc.
Now go to snap disc #1 and do the same thing to find out which wire has 110 volts going to it. Since this one is a normally open contact, you can just probe the two sides of the snap disc. Unplug the stove and remove the wire that had the 110 volts and tape it up securely. You won't use it. Connect the other end of the new wiring harness that is 24" from the other end to the open terminal on snap disc #1. You're done. Plug it back in and hope it doesn't smoke
I'm no lawyer but I have to say that you do this ALL AT YOUR OWN RISK! I CANNOT CONTROL WHAT YOU DO OR HOW YOU DO IT! %-P
Now you see why a picture would not tell the story.
