barnaclebob
While the fire is going good, play with the air controls. When you close it down you should see the flames slow down and maybe go away. When you open it, the fire should be looking nice and alive, almost like an open fireplace fire. When you start the fire you want the air controls fully open.
Wet wood will eventually burn but takes a longer time and more kindling to get to a point where it wont go out. It will be less efficient at heating since you have to boil away all of that water and it can create more creosote in the chimney.
For long burns you need to set the air control as low as possible without the fire going out.
![[Hearth.com] Quadra Fire 3100i doesn't heat the whole house [Hearth.com] Quadra Fire 3100i doesn't heat the whole house](https://www.hearth.com/talk/data/attachments/231/231862-6ea24552fb667999a6e02a5263b47373.jpg?hash=sXnRpcAzPj)
![[Hearth.com] Quadra Fire 3100i doesn't heat the whole house [Hearth.com] Quadra Fire 3100i doesn't heat the whole house](https://www.hearth.com/talk/data/attachments/231/231864-bc8f3cebc2cddfdb95aa1ace431863cf.jpg?hash=xblb5sPbIr)
![[Hearth.com] Quadra Fire 3100i doesn't heat the whole house [Hearth.com] Quadra Fire 3100i doesn't heat the whole house](https://www.hearth.com/talk/data/attachments/231/231879-799c54703cc03c541b233b4eeabaf1cd.jpg?hash=iRyFAbEjdO)
![[Hearth.com] Quadra Fire 3100i doesn't heat the whole house [Hearth.com] Quadra Fire 3100i doesn't heat the whole house](https://www.hearth.com/talk/data/attachments/231/231882-46be6247e61bdd3c03f7372345978843.jpg?hash=NEV_WevI7m)
![[Hearth.com] Quadra Fire 3100i doesn't heat the whole house [Hearth.com] Quadra Fire 3100i doesn't heat the whole house](https://www.hearth.com/talk/data/attachments/231/231884-f5b6795ba37ce1d0edae6ec51789fc6b.jpg?hash=lH_w8hv_EP)
![[Hearth.com] Quadra Fire 3100i doesn't heat the whole house [Hearth.com] Quadra Fire 3100i doesn't heat the whole house](https://www.hearth.com/talk/data/attachments/231/231883-5480b38178f269bda51842ef1df0d162.jpg?hash=K1KsbEUHV8)
![[Hearth.com] Quadra Fire 3100i doesn't heat the whole house [Hearth.com] Quadra Fire 3100i doesn't heat the whole house](https://www.hearth.com/talk/data/attachments/231/231903-0f79abf7f954d18aad9ff4e4f819115b.jpg?hash=d8UFtUy56G)
