Hello eveyone
Our current wood (only) furnace, a newmac is getting alittle old and we have been looking at a PSG caddy as a possible replacement. We heat roughly 1500 sq. feet with our newmac, consuming 10 cord of wood (black spruce) over the fall/winter/spring. If you own a PSG caddy, I would really like your input on the following concerns:
How thick is the superior plate and have you experienced any burn though?
Will the caddy really use less wood?
We have to keep our house really warm (25 deg. C and over (77 F) for the comfort of a disabled family member, can the caddy handle it?
Our newmac has a forced draft (small blower) set-up which runs nearly continuously to keep up with demand, how does the caddy compare to a forced draft set-up?
We will get some puffing with Southerly wind, is the caddy anymore prone to this than other designs?
We have an external brick chimney and have the furnace located in the basement. We cut and haul our own firewood during winter, allowing it to dry over summer, and enjoy all aspects of wood heat.
The caddy certainly looks like a great furnace but I'd like some owners'opinions on these specific things and anything else you can think of.
Thanks... Glenn
Thanks... Glenn
