I am the owner of a new Regency i3100l stove insert. I have been having some issues getting quality burns out of the unit both in terms of duration and heat output. I need the unit to heat my entire living area. This is about 2600 sq. ft. The last week I have been using mildly seasoned ash/oak/cherry mix. I was told it was seasoned 2 years when I bought it but this cannot be true. Now, because it is not well seasoned, I was getting a lot of sparking and sizzling, as the moisture evaporated. Only getting 2-3 hour burns max, and sometimes need to leave the air control completely open to maintain the presence of a flame. So I went out and found some well seasoned wood and this is what I did next...
I took some well-seasoned ash (split & stacked 3-4 years) and I wanted to see what kind of burn a large load would result in. I need to figure out how to get the longest overnight burns possible. So, I started by adding 3 small splits to the fire. These were consumed within 1 hour. 3 more logs, again maybe 1.5 hours. Then I decided to load it up and see what I could do. So, I placed two large splits left to right, on top of the remains of the previous, semi-solid burned splits, and then 4 more smaller splits front to back. I shut the door and opened the air flow control, until the fire seemed very hot. However after about 3 minutes of this, one of the combustion air tubed began to turn dark to mildly bright red. So, I closed off the air. It seems strange this would happen as it should not have overfired so quickly. For about 15 minutes the fire burned hot with the air flow closed off, and in only one corner of my box was there secondary combustion. Then, after 1/2 hour, there is no secondary combustion, but evenly distributed light flames (with a bluer tone than I previously remember). 1/2 hour after that and the flames are dying down and the splits are more glowing orange than burning with flames. The flames flicker only inches above some of the orange glowing splits and there is definitely no secondary combustion.
I have not been able to get burns of more than 3 hours from the insert, no matter what I do. I have literally sat for days in front of this thing, staring at it and adjusting the air control this way and that, trying to understand the most efficient way to operate it. Good thing I like to watch fires! Keep in mind my firebox is relatively large, being 3 cubic ft. Perhaps someone might point out what I am doing wrong or what I should be doing? Is there a special way to place the splits in the firebox? Should I not be placing a large split directly in front of the glass door (will this block off the fresh air coming down and over the hot embers??). Should the unit always have secondary combustion, and if so, how does one go about maintaining this without manually adjusting the flow control every 15 minutes...I need more sleep than that
Also, how important is the heat of the ash base? If the ash base was created by the mildly seasoned wood I have been burning for a week, could this adversely effect the burns of even well-seasoned wood?
Thanks.
Thanks.
