TheRambler
Is the PH 700 lbs.? That's heavier than I had guessed, originally thinking it was 550'ish.
780 i think. 700 something
It is small but I wouldn't say no advantage.True, but the point remains the same. 700 lb of soapstone won't have any heat capacity or latency advantage over 500 lb of steel, when placed within the envelope of a 1 million pound house.
What do you mean by 200 lb difference. I though we were talking about the fact that soapstone retains heat. I have lime stone walls about 3 feet wide and once they get cold well the house is cold.Yes, very, very, very small. Just looking at the 1770's wing of my house, it would be a 200 lb difference on roughly 1 million pounds weight. So, ignoring the small factor of heat capacity in the last 500 - 700, it's 0.02% difference. Results maybe more significant in newer construction, but still probably always below 1%.
I dunno...I want to burn cleanly, so in the shoulder seasons I just open the windows and turn on the WHF!Curious. More heat is not always desirable, especially when it's 50F outside. Low slow, shoulder season burning is one of the sales points for cat stoves. What is the best way to run the PH for the longest burn time? Cat disengaged?
Sacramento has shoulder season temps all winter.I dunno...I want to burn cleanly, so in the shoulder seasons I just open the windows and turn on the WHF!Just crazy me
Despite comparibg the PH to a stone house...
My stove room stays hot for quite some time after the fire goes out. For like 4-5 hours or much longer. I loaded my stove last night at 6pm. Stove top is still 150 at 322pm today.
It might not be alot, but its not all hype. 150F 700lbs rock still keeps my main floor fairly comfortable, especially in the stove room. That NEVER happened with my old stove.
I often use the stove top to keep my coffee warm about 6-8 hours after the fire has gone out. Thats justs a bonus!
You're missing point. I'm talking about energy storage, and whether an extra 200 lb of stove makes any difference in how long your living space stays warm, after the short burn time of that PH lets you down. In that equation, you must consider the temperature, mass, and heat capacity of every heated object in your living space. In that grand sum, 200 lb is not substantial, even when taking into account the relatively high heat capacity of soapstone. That is all.
Example, my stoves are each located in a fireplace, roughly 8' wide X 6' deep X 2 stories tall, and 18" solid stone on all sides. When the stoves go out, those fireplaces stay warm for days. Even with all that mass sitting at an elevated temperature, the house still goes cold, because it is just a small fraction of the total heated surface exposed to the heated envelope, and no where near the surface temp of an actively burning stove.
Physics is simple, BTU out = BTU in X efficiency. Soapstone is a small capacitor, short time constant in that function. It's not buying you any extended heating that came from anywhere beyond the time lag you experienced at start-up.
ok so hows it burningChestnut...I was lucky to live near the American Chestnut Foundation. They had gotten down to their final hybrid and just bulldozed their older stock that they didn't want bread anymore (they were crossing Chinese chestnut and American chestnut) I went over for a few afternoons about 5 years ago and cut up a bunch. Just about as much free would as you could want.
Were u trying to make a joke burning a hybrid in a hybridseems to burn well, but i am no authority on the matter. i've really only had my wood stove in operation about 3 weeks with nothing to compare it to.
Black box means no flames in the firebox, so the stove is operating in pure cat mode. I don't do that because mine has a habit of backpuffing.
I have also found I get better cat lightoffs and a much cleaner flue by burning with the air open a bit.
