rideau said:What a perfect day. Heading back out in a minute. Can't bear to waste the day inside. Just a quick update on the stove. It continues to please me. Easy to run, and heats very well. Far more suited to actually heating the house than my Fireview. I have not run into any problems with the cat, other than the early time it and the screen clogged. Used a fan on the floor in the hall, about five feet from the stove room, pointing into the stove room, which gives the fan ability to draw air from the kitchen via the two-opposite-wall-door-bathroom under the stairs, as well as from the stairs at the south end of the hall (that stair has four steps up from the kitchen on one side and the hall on the other side to a landing with windows, before stair turns and goes to second floor, so there is good airflow). Have never used a fan before to spread heat. It does keep the temperatures on the first floor much more even. Ranged from 68 in kitchen to 74 in stove room. Without the fan I was running about four degreen cooler in the kitchen with the 60 MPH winds from the south yesterday. The one thing I have not been able to do is get this stove (stovetop, I don't have an IR gun) over about 520. I have to admit I have not killed myself trying to do so...but it doesn't seem to want to get hotter. I do have active secondaries, and plenty of heat, so I'm not worried. But I am curious about what heat output would be if the stovetop was 600. I'm burning very good, dry wood. Same as I've always used. No issue with it's performance. Same wood in Fireview would easily run into a VERY hot fire if I left damper open by mistake. This does not happen with this stove...maybe it would if I left damper all the way open for a really long time, but certainly doesn't in the twenty minutes max I have left it fully open with a fresh load. So, I consider this stove very safe. Anyone care to share what they have done to get their stove up to 600 or so?
I've gotten up to 580 on occasion, not for trying or wanting, tho. As I recall, the depth of the coal bed was a factor in determining the final high temp of the stove top, the deeper the bed, the higher the eventual temp. But, take this with a grain of salt, my memory is NOT what it used to be :-S and it's been awhile since I've gotten up that high a temp. Possibly, also running with the damper open 50% or so for awhile after closing the bypass. My Progress has been performing brilliantly, too.
