I pulled out the home built unit that was installed in the basement today to get ready for a purchase of a new wood furnace. I am planning on the Daka from Menards but now I'm not sure it will work.
Any advice appreciated.
The existing hole in the chimney is a whopping 9 inches. The center of the hole is only 55 inches from the floor. The top of the pipe out of the Daka is 41". I'm thinking this isn't enough room for a baro damper much less a regular damper even if I go to the top of the existing chimney hole. By my math it leaves 18" from the center of the flue pipe to 3" down from the top of the chimney hole.
A USS 1557 from TSC would give me maybe another 1.5" since it's a shorter unit.
Is my only option to knock another hole in the chimney higher? I'm not sure that's a good idea from a structural standpoint.
Any thoughts? Go with it but skip a baro damper?
*edit* the current chimney size is, I think, 11x7.
