Ashful
If you have 2 acres, finding room for a few cords of storage should be do-able. The bigger challenge may be making access to/from said storage convenient. I'm on about 4 acres, and at times I've had as much as 30 cords CSS'd + 10+ cords in logs, all jammed into one little 1/8 acre corner of my yard. That does get crowded, difficult to even move the logs around, but it's do-able. Now I'm holding around 16 cords CSS'd + 15 cords in logs, in the same space around 1/8 acre, which feels downright roomy.
In laying it out, consider your path in (logs or rounds), FIFO storage for un-processed and processed wood, with space between these two areas for processing, and your path out for processed wood going to the house. I can measure and draw up my layout, if it helps, but your ideal setup will be different if you're using different equipment.
