bwise.157
Burning Hunk
(broken image removed)
I like that carry-all, bwise. I've been thinking of making one myself, but with expanded steel sides and angle stock, instead of plywood. How heavy is that wood box? My 3-point is only cat.1, so weight is a bit of an issue. I can lift 1100 lb. at the pins, or 785 lb. at 24", which is probably where the center of gravity of that box would be.
edit: I see you have a model 70 loader, the same spec'd for my 855. I have the model 52 loader on mine, though, which is supposed to be a little heavier than the 70. Not sure that's true, though. What model is your tractor?
Copy as much as you want! Lowes didn't have the casters in stock, so I had to order them. They had small ones, but nothing that would support the weight I would have. The ones I purchased were rated at 300lbs each.I like this. I think I could build TWO for my lower patio, where I have always stored a cord of wood during burn season, and a third in my attached garage. Then I'd have wood handy at either end of our long house, for the stoves located... at either end of our long house.
Attaching casters to the bottom is a stroke of brilliance. I hope you do not mind if I copy!
Yep. Adjust for your center of gravity. However, of the three implements I have for my three point, two of them have their COG very close to those link ends.Yea thats at the end of links bit most things hang several feet off the end.
Really 535
Oh so there is a super charger on it!!
It's a redneck contraption - may be as simple as they could! The box could hold what - 1/16 cord?Why the dual rear wheels????
