Hi all,
I just spent an hour or so reading @rosen431 post and all the replies last night while I let the adrenaline wear off. I learned a huge amount but I still left with a question or two since my stove is different. I have a Jotul F118 Black Bear stove placed in my basement in the center of the house. I have double wall pipe with an adjustable connector near the ceiling. Then I have approximately 20' of triple wall that goes through my main floor and attic then exits close to the center peak of the roof.
So it was late evening and there was a bit of a rush to get a fire going so that we could eat. There is story in between but the end result was that we had the firebox full of much smaller splits than we usually use including a couple 1" pieces of pine and one of those tiny square fire starters (I thought I could cheat and not have to sit there so long trying to get it started....
 ) . The fire was left unattended while we went upstairs to nuke leftovers real quick. We were walking by the stove pipe on the main floor with our plates and were headed downstairs to eat when I thought I heard maybe a mouse by the pipe. I quickly realized it was the pipe making little tinkly noises. We raced down the stairs and the stove top temp was around 500° but the flue temp was at 1200°. I had NEVER seen the flue temp exceed 500°.
My first reaction was to slam the air on the door closed. Obviously nothing happened in the first few seconds and I changed my mind and threw the door wide open. My husband looked outside to see if there was anything visible and I futilely directed a small fan at the stove. The tinking sound continued for what seemed forever but was probably only a couple minutes.When the flue temp did come down it fell extremely fast. It did slightly melt the labels on the adjustable elbow but I didn't feel heat at the floor penetration into the main floor.
I'm assuming, based on reading the other post, that we most likely had a small chimney fire. After all this reading I'm wondering if our stove top Thermometer is really showing stove temps since it sits on top of the stove and there is this heat exchange chamber between it and the actual fire? Jotul says to burn between 400°-600° as indicated on a thermometer "placed directly on the top plate". It also says in the event of an overfire or chimney fire to close the air on the front door and let it cool.
Also, if I have never seen flue temps above 500° before this are we burning way too cold? We generally start shutting the stove down when the stove top thermometer gets to around 350° which is in the middle of the "best operation" zone on the thermometer. It may register 50° low. I'm going to try to post photos with this post.
I've plan to have a timer handy and have ordered an electronic thermometer with an alarm. We will never again use that many small dry pieces of wood and walk away. Any other bits of advice for this stove would be welcome.
 ) . The fire was left unattended while we went upstairs to nuke leftovers real quick. We were walking by the stove pipe on the main floor with our plates and were headed downstairs to eat when I thought I heard maybe a mouse by the pipe. I quickly realized it was the pipe making little tinkly noises. We raced down the stairs and the stove top temp was around 500° but the flue temp was at 1200°. I had NEVER seen the flue temp exceed 500°. My first reaction was to slam the air on the door closed. Obviously nothing happened in the first few seconds and I changed my mind and threw the door wide open. My husband looked outside to see if there was anything visible and I futilely directed a small fan at the stove. The tinking sound continued for what seemed forever but was probably only a couple minutes.When the flue temp did come down it fell extremely fast. It did slightly melt the labels on the adjustable elbow but I didn't feel heat at the floor penetration into the main floor.
Ok need some help understanding this. Forgive the long post....Started a fire today loaded up beech and ash in my Woodstock ideal steel hybrid, very well seasoned. Filled the fire box. 35 ft stainless liner from the basement wood stove up through middle of my house, so drafts hard. Especially when cold. I had her cruising along nicely in a black box cat burn (no flames). Pipe damper half closed and stove damper almost all the way closed. Stove top temp starts to get near 600 flue gasses at 500 and I close the intake air on the stove all the way (still gets some air, but basically had it on the lowest air setting), and closed the pipe damper all the way to cool it down and keep the burn where it is. I have a probe thermometer in my double wall so that’s where I’m getting the flue gas readings. Now things get interesting - stove temp stays around the same, creeps up a little but the flue gas temperature starts rising FAST. Goes from 500 to 1200 in like 2 minutes and I smell that paint curing smell. Outside double wall at the hottest spot was about 500 degrees! I call a buddy of mine, he says “open up the pipe damper all the way and the stove damper all the way. If that doesn’t work open the door - you need to flood it with cold air”. Sure enough I opened up the pipe damper all the way and the intake air halfway and the flue temp starts dropping immediately. What am I missing here? Only thing I can think of is I kept more smoke in the stove and that just got the cat going even crazier? Second time this has happened in 10 days and last time I warped the radiator cover pretty good. Aside from adding less fuel, what’s actually going on?
	![[Hearth.com] Possible Chimney Fire Version 2 [Hearth.com] Possible Chimney Fire Version 2](https://www.hearth.com/talk/data/attachments/275/275671-df538ea0c6538849a8b2cbfb95f12298.jpg?hash=biDVBcstQx)
![[Hearth.com] Possible Chimney Fire Version 2 [Hearth.com] Possible Chimney Fire Version 2](https://www.hearth.com/talk/data/attachments/275/275672-29957380b3bdd7f42cba1eb800ea1924.jpg?hash=jceaBKorzv)
![[Hearth.com] Possible Chimney Fire Version 2 [Hearth.com] Possible Chimney Fire Version 2](https://www.hearth.com/talk/data/attachments/275/275673-d7fbca22d29a0757cafb921ed768108d.jpg?hash=V-cT0R1sk-)
![[Hearth.com] Possible Chimney Fire Version 2 [Hearth.com] Possible Chimney Fire Version 2](https://www.hearth.com/talk/data/attachments/275/275674-75f092469672206d1b13cf1d0649a49c.jpg?hash=gAVKAjgmVn)
